Question about Vizio Televison & Video
My vizio now has a blue screen that say's no signal, then turn off
  • brianflartey Apr 25, 2010
    Thank you for your solution. Upon further inspection an HDMI cabel was unplugged and you were right the source was wrong. This tv is mounted about 15ft near my cathedral ceiling and would have been a hugh job to repair. Thanks again!
  • Vizio Master
  • 2,005 Answers
Make sure you have the menu set for the correct video source, using your remote, test the set.
Remove the video feed coax cable and, all other "video in" wires then: retest (you may have a signal cable failure) If the set still acts the same way you have a short in the tuner circuit causing the power supply protect circuit to shut down to protect the set.
Posted on Apr 25, 2010
Blue screen vizio vo371
Blue screen could be a bad main board or a no signal issue---do you get picture with DVD player connected?
Aug 29, 2012 | Vizio VO37LHDTV10A 37 in. LCD TV
Gv 42l power blue screen no signal
Yes, a cap will rarely cause this issue.
If blue screen set is ok power wise.
If blue when connections are made to rear inputs also it means it is not the tuner in the set---a good idea is to hook a DVD up, turn it on and then the set--select that input with the DVD already on--
That aside you may want to make the effort to call Vizio and see if this is a known issue or if a software upgrade is available for this issue.
If I had to "guess" it will be the main board that processes all signal inside the set.
Do some research with GOOGLE by model number "known problems" blue screen only etc.
Apr 01, 2012 | Televison & Video
32in vizio tv problem. blue screen
You can if it has it connect to cable fitting and or the various av jacks on set---use original remote and switch inputs to make sure you are on the one you are hooked up to.
Mar 12, 2012 | Vizio Televison & Video
How do I turn Off the RGB no signal screensaver on my VIZIO ? Everytime I get comfortable on the couch it goes blue screen on me and makes me get up to move the PC's mouse.
the problem is on the pc my friend not the tv, right click on the desktop of the pc and click properties or screen resolution then click on screensaver .then change the turn monitor after 30 minutes or whatever its set to , to none. Then your tv wont show no signal as the pc wont be turning off the signal
Mar 30, 2011 | Vizio GV42L 42 in. LCD Television
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L37
you probably changed the input mode.
Nov 10, 2007 | Vizio L37 Television
Televison & Video Logo
27 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
