Question about GE (PSS26MSRSS) Side by Side Refrigerator
WHAT YEAR WAS ge MAKING THE tfx22prxb - GE (PSS26MSRSS) Side by Side Refrigerator
My Microwave is making a loudbuzzer noise when it's on
HI Dianne,
The loud noise you describe can be from two components, I would advice to have the unit checked. The repair could be cheater then replacement, when it comes to microwaves, aftermarket parts are cheaper. I would suspect the magnetron or diode would be the problem in this description you gave above. Some of the GE models had a 10 year warranty on the magnetron, so check your user manual before having the unit serviced, it maybe under warranty for the repair anyways. You can always call GE for a warranty status on your unit as well. Good Luck
Apr 24, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
The microwave runs but it doesnt warm up the food. it also is making a funny noise.
if the sound is a buzzing noise, it is probably your magnetron, most GE microwaves have a 5 or 10 year warranty on magnetron, all you may have to pay is labor
Aug 24, 2010 | GE Microwave Ovens
We have a 4 year old GE fridge that is ticking like a clock but louder. the model number is GBS20HBSBWW
If the inside fan does not come one, suggestions are "bad mother board", possibly a free replacement from GE, that otherwise is $300+.
May 27, 2009 | GE GBS20HBSWW 30" 19.5 Cu. Ft....
Replaced a water valve but still makes a chugging sound.
Get scouring pad (green pad) from supermarket and remove cutting try. Use pad and cleaning solution to really scrub the evaporator tray until slippery clean. Use forward to backward strokes, not left to right. Clean all surfaces of freezing tray and that should help.
Apr 11, 2009 | GE Monogram ZDI15C Automatic Icemaker
Frost build up in freezer and warm temp in a GE Profile TFX22PRXB
Modern refrigerators are designed to self defrost and it is essential to the airflow to have an evaporator coil that is clear for air movement. If the rear interior panel of the freezer has frost appearing, it is most likely a defrost problem and must be corrected before temperatures can be restored to normal. Your refrigerator most likely has a defrost timer located on bottom behind grate, or inside behind control panel. Could you find the correct model number so I can help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 24, 2009 | GE Refrigerators
My GE window air conditioner is making a loud harsh sound, I just turned it on for the first time this year. It did not do that last eyar.
best thing to do is to see if theres something hittng the fan blades,if thats clear the other that would make such noise would be the compressor,
Mar 18, 2009 | GE Heating & Cooling
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
199 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
