Question about GE Dishwashers
Water remains in bottom, water pump out? - GE Dishwashers
    President:
  • 949 Answers
It sounds like one of two possibilities here.
The most likely is a blockage somewhere between the drain pump and the drain in the house (under the sink).
Places to look for this would be an air gap or the fitting where the drain hose connects to the house plumbing. Take the drain hose from the dishwasher off of the house pipe under the sink, run that hose into a bucket and see how it drains then. If it is poor then follow back toward the dishwasher until you find the next junction or fitting. If you are sure all these are clear and still not draining, you will most likely need a new drain solenoid.
Posted on Apr 25, 2010
HOW DO I DRAIN REMAINING WATER FROM BOTTOM OF DISHWASHER
Thank you for your inquiry, friend!
I see that you need assistance in draining the remaining water out of your Frigidaire dishwasher. It is normal for a little water to remain inside of your dishwasher. If it is more than two or three inches it could be a draining issue. I would check to make sure the drain hose is not clogged or restricted. You should also review the filter, which you can find under the bottom rack, to make sure that it is not clogged. If you have reviewed these steps and water still remains it could be a possible issue with your drain pump. I recommend having a professional technician out to perform repairs because this will require you to uninstall and disassemble your dishwasher. I hope this information is helpful. -Matt
Feb 27, 2015 | Frigidaire Dishwashers
Whybdoes water remain in machine at end of wash?
If the drain pump malfunctions...or is clogged then it will not empty within the time cycle and the unit will time out. the pump in at the bottom of the machine
May 21, 2014 | Maytag Neptune Washer
Dirty water standing in the bottom of the tub
There is probably some debris that is blocking the water from getting to the pump.For More information please visit Kenmore Parts.
Oct 04, 2012 | GE Nautilus 24" Built-in Dishwasher
How do i access pump which needs cleaning
LG Front Load Drain pumps are located at the bottom left hand side of the machine, it has an opening. You can open the door, and pull the small black hose out, and manually drain any remaining water. Once the remaining water is out, you can unscrew the black cap, which is the clean out.
Mar 06, 2011 | Washing Machines
Water remains in bottom of washer and will not drain
Possible failure of the drain pump as it fails to ****/pump out the total waste water remaining in the tub. This can be due to a poor pump action, clogging of the waste in the pump reducing the pumping quality.
You might have to remove the pump from the base hose fittings , use a good flushing , test and reset to solve the issue.
Nov 29, 2010 | Dishwashers
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Water left in compartment
You need to elevate your dishwasher drain hose under the sink. The water going down your disposal side is running down the hose into the dishwasher.
Nov 05, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Water remains in bottom of dishwasher
a little water is supposed to remain in the bottom so that the pump will not lose prime when it starts to drain
Oct 24, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Water stand in bottom of unit.
rep;ace the water pump impeler Vitally
May 02, 2009 | GE Profile PDW8600J Built-in Dishwasher
Bosch shu9925
take bottom front panel off to expose the bottom tray. you will find there is water in it. mop water out and appliance will operate ok. turn off at mains first.
if fault reoccurs, you have a leak which will have to be traced
Aug 30, 2008 | Bosch SHU9925UC Built-in Dishwasher
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
