Question about HP Pavilion dv6000z Notebook
Vertical grey line during boot sequence
My computer at start up ...the screen is white/gray and it looks like the screen is rolling
  • 54 Answers
Check it in bios, if it is there then its a h/w fault. send it in for repair.
if not then refresh the graphics driver.
Posted on Apr 29, 2010
My apple iMac will not boot up i have a grey screen with an apple
Please carefully do this while grey screen during start up Mac OS Gray screen appears during startup. if you need any technical guidance Apple Customer Service .
Jul 15, 2014 | Apple iMac Computers & Internet
Vertical gray lines
If you can obtain a desktop monitor used for PCs, plug it into the side port on the laptop. Start up the system and see if it runs OK on the external monitor. If so, the problem is with the LCD display on the laptop.
Feb 27, 2014 | Acer Aspire Computers & Internet
My dell monitor screen, s2209w, is blinking and asks for password
Check in in the BIOS,(Press F2 key during the start up) if the same thing u see in than BIOS replace the monitor.
Aug 01, 2010 | Dell S2209W Monitor
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
Upon starting the 1995 Camry the engine dies. There is also grey smoke coming from the tail pipe. Checked the oil and there is no water in it.
Is it gray, bluish gray, or white? White smoke, during warm weather, indicates that you have a head gasket out and it's vaporizing water, it will look much like it does when you first start it on a cold day. Bluish gray indicates burning oil, which could be bad valve seating, severe engine wear on your piston rings and oil is blowing past them into the combustion chamber. Grey smoke is probably water as well, though it could be contaminated with oil, or the vehicle could be running too rich, getting too much gasoline. But typically this is more of a black smoke than gray.
Nov 10, 2009 | 1995 Toyota Camry
How do i change the boot sequence. I have the Compaq sr1630- win xp os. Installed new hard drive after disk to disk copy. System has the Phoenix - Award Bios CMOS topman
During boot there should be a notifaction at the bottom of screen saying something like "Press Del for bios and F10 for boot menu" or something like that with other keys. If there is a boot menu option press the corresponding key and you will enter the boot menu. Here you can set the drive you want as first, second and depending on the motherboard third boot device.
If there is no boot menu option, enter the BIOS and go to advanced BIOS options, or something like that. There should be located a submenu called boot sequence, in which you can adjust the boot sequence too.
Jul 22, 2009 | Compaq Computers & Internet
Red roller part number
That is most likely the upper fusing roller with the line on it. I don't know if it is possible to just replace the roller. The source that I use only offers the complete unit (2 choices) one has a white connector, the other has a grey connector.
Apr 19, 2009 | Office Equipment & Supplies
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
HP Pavillion ZV5405 with Black/White vertical lines through screen
Will it boot from a CD/DVD? Make sure the boot sequence is set to boot CD first and then see if it will boot into setup from a CD/DVD. If it will, then maybe try reinstalling windows. Hope this helps.
Aug 21, 2008 | Acer Aspire 5100 Notebook
I have a white bar on the right side of the screen.
This is caused by either a bad address board (low $) or a bad plasma panel (high $). The only way to know is to replace the corresponding address board and see if it repairs the line. Hope this helps.
Mar 11, 2008 | Samsung HP-T4254 42 in. Plasma Television
HP Pavilion dv6000z Notebook Logo
204 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
