Question about True T-49 Side by Side Refrigerator Commercial
Have a True single door refrigerator. Refrigerator worked ok. Power was shut off about 3 years ago. Refrigerator will not come on now.
    Guru:
  • 1,524 Answers
Check voltage at compressor.
Posted on Apr 25, 2010
Check water line good pressure to connection does not want to go go true the black box on the back
Free True Manufacturing Company Refrigerator User Manuals
kitchen.manualsonline.com/manuals/.../true/true_refrigerator_product_lis...
Products 1 - 33 of 33 - True Manufacturing Company Refrigerator GDM-3. True Refrigerator Swing Door Installation Manual. Pages: 0 Saves: 0. See Prices
True Manufacturing Parts and Manuals
Dec 14, 2015 | True Refrigerators
I have a 2 door refrigerator not sure if exactly this model number mine says tp-125-ap-021-a2 also i see numbers that say tpa0413yxa mine also has 2 stainless steel shelves above it. The problem started...
These numbers do not match anything I can find. Overall, it sounds like the evap fan blade has an issue. Either it has come loose or hitting something and hanging up.
May 16, 2017 | True TWT-60 Stainless Steel Commercial...
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
It kept running, clicking to try and shut off but couldn't. Freezer thawed. I shut off for a while, vacuumed coils, turned back on and it ran fine for three days, working perfectly. Next morning repeat...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Amana ARB1914C Bottom Freezer Refrigerator
Freezer and refrigerator not cooling
1 Check if the gas has not leaked out. 2 Check the condenser if it is working OK 3 Hope the compressor is working
Jan 13, 2010 | Maytag MFI2568AE Side by Side French Door...
The regrigerator is not working at all. Checked
If you tested the outlet and have power there,I would call the manufacture if it's only 3 months old. You have 1 year on all major brands. It's most likely a bad compressor. Frigidaire's are bad for this just to name one.
Sep 06, 2009 | Maytag MFD2560HES Bottom Freezer French...
My LG freezer is cooling while the refrigerator doesnt.
OK THEN FROM WHAT YOU SAY SINCE THE FREZER WORKS BUT NO FRIDGE IT SOUNDS LIKE A DOOR SEAL FOR THE FRIDGE DOOR GONE BAD,DIRTY,WARPED,OR WORN OR THE DOOR IS'NT SHUTTING ALL THE WAY THIS IS THE NEXT STEP OF WHAT TO LOOK AT
Apr 12, 2009 | LG LRTBC1825T Top Freezer Refrigerator
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
True T-49 Side by Side Refrigerator Commercial Logo
122 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
