Question about Brinkmann Charmglow 810-7400-S Propane Grill
Bought new ignitor still will not put spark to burner
  • 140 Answers
Did you change the battery and it could be the starter
Posted on Apr 28, 2010
This is aCG4TDBN (elite with no back burner) aprox 6 years old. The ignitors are starting to go bad. How do I replace them?
First, you need to determine if it is the spark ignitors going bad or the Ignition Module.
If the spark ignitor tips are covered with grease or residue, this will give them the appearance that they're failing. Cotton balls and alcohol, work well to clean the spark ignitors. Also, check the wiring from the spark ignitors back to the ignition module. There may be some wear or even a burn on the wiring. Change the battery in the ignition module. Be sure the new battery is facing the same direction as the old battery, when you install it. Before installing the new battery, check the battery holder for corrosion on the contacts. If you see any, use a Q-Tip and WD40 to remove it.
As far as replacing the ignitors is concerned, you may only have to replace the spark ignitors and not all the wiring. It depends on how the wire is attached to the spark ignitor. If it can be carefully pulled of the bottom tip of the ignitor and then si back on, all you need is the spark ignitor. If not, you'll need the spark ignitor with the wiring attached. All of the wiring, will then have to be fished back to the ignitor module.
More more info on all the parts you may need contact BBQ's Galore 800-752-3085.
I hope this helped you to troubleshoot and determine if any parts do need replacing.
Jun 30, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
Burners two and three will not light unless direct flame is put to it. Burner 1 will light off the ignitor.
Probably the ignitor sparker is not positioned properly or ignitor wire has short and it's not sparking at the burner. Compare the position of the one that lights with the others that don't and adjust position til spark arcs against burner and lights within 1-3 sparks.
May 12, 2010 | Char-Broil Advantage 463453306
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
VDSC 365-40, Suspected right side ignitor box bad. Repairman came, obviously didn't know Viking, tore into unit and confirmed bad ignitor box. Estimated $450 to repair. I put in new box myself. Works...
You have to identify the thermocouple by the flame. Some units run sparks constantly to insure that tha flame stays lit. If you see the thermocouple bulb by the flame it is bad and needs replaced (he may have bypassed it also let me know)
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m10110_viking_primer_2005.pdf
It would be helpful if you have a multi meter. Sorry you are having trouble with the repair man. I hope I can talk you through this but if he has made a mess it could be 10 times more work for you. Txtooltime@aol.com
Sep 02, 2009 | Viking 30" Professional Select Built-in...
Ignitors on three burners start when using a burner & dont stop
if you dont have mice that chew and short out wires,you need a new spark moudel
Dec 31, 2008 | Viking VGSC306-4B Gas Kitchen Range
Large burner only sparks for other values to light and won't light by its own switch
sounds correct, if it didnt spark at all and you had not replaced the igniter I would check that the wire from that igniter be followed to the other end to verify that it had not come unplugged at the other end.
On a new range I bought that igniter would not spark even though the others did and its wire was unplugged
Oct 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Aug 26, 2008 | Jenn-Air JGS8850BDS Stainless steel Gas...
Brinkmann Charmglow 810-7400-S  Propane Grill Logo
188 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
