It gets to rinse and will not drain - Washing Machines
  • 77 Answers
Most washers will not spin and drain if the lid is not closed check the lid switch to make sure it is working if not replace it
Posted on Apr 26, 2010
Washer will stop after rinse cycle and says OE. Then is will not drain rinse water.
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | LG Washing Machines
Not draining after rinse cycle
replace the timer it has a bad spot inside of it in this segment of the timer and isn't passing voltage for spin,when you forward it then it gets power again,they do wear out too
May 14, 2010 | Maytag Atlantis MAV6000 Top Load Washer
It will not drain the water on the rinse cycle
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 24, 2010 | Maytag Washing Machines
Washer won't rinse & drain
The lid wasn't locking in all the way- when we put something heavy on top of the latch it started working.
Sep 15, 2009 | Whirlpool Washing Machines
Front load washer, will not do final rinse
A lot of times it is the strainer clogged at the pump. Hope that helps.
Sep 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Problem draining &spinning
Get the strings coins and sand out the pump and retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2008 | Fisher Paykel EcoSmart GWL15
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
