Question about Southbend 436D-2GR Gas Kitchen Range
Southbend model : x436d need to connect to lpg bullet does not have a regulator on the range do i need 1 before connecting
    Top Expert:
  • Southbend Master
  • 42,852 Answers
Spot on answer
Posted on Apr 22, 2015
How do I raise the pilot light so my oven to come on help me o no that's just like it in the schoolke
    Habit-Forming:
  • 193 Answers
Off the bottle you will need a regulator and at the back of the stove you will need a yellow gas tap as an isolator remember bottle pressure can reach as high as 1200kpa on a hot day and you only need 2.75kpa for the range and your line size is 1/2'' and use gas tape on all fittings and leak test with soapy water
Posted on Apr 26, 2010
The timer works sometimes and then other times it won't...any ideas?
Hello. Your issue might be a defective timer. REMOVE POWER FIRST!! Definitely check for loose(or burned) wiring connections. Over time, the contacts can oxidize and/or heat can loosen the spade lug connectors that attach the wires to the control. The exploded parts diagrams and parts lists can be found here: http://www.partstown.com/is-bin/INTERSHOP.enfinity/WFS/Reedy-PartsTown-Site/en_US/-/USD/ViewExplodedDiagram-Show?CategoryID=iCrUwxtSbaquiXjVOSUqRhaJMk
Parts Town Southbend Range SLES 20SC Electric Convection Ovens Parts Manual . I hope this helps you!
Sep 16, 2015 | Star Southbend "silver Double Convection...
Range rover 3,9 1990 runs on lpg but will not run on petrol
check all fuses think fuse for pump is under drivers seat on uk models. If fuse ok check for power and earth at the connection on fuel pump. if power and earth possible fuel pump.
Mar 06, 2014 | 1990 Land Rover Range Rover
Rpm 30 mph
IF you are on lpg then check that the gas regulator for icing up and stopping the liquid LPG from turning to gas. If it cuts out on petrol check that there is not a problem with the petrol shut off solenoid . Check the LPG cut off solenoid . I suspect a loose connection or wires to either or both or faulty units
Dec 02, 2013 | Land Rover Cars & Trucks
I need to calibrate my southbend model #x436d standard gas oven
If you pull the knob off there is a very little screw in there that you can turn with a small screwdriver. I believe left is increase and right is decrease, but I could be wrong. Very little turns do a lot. You can tell if you are going the right way if the burners get bigger or not. This takes a while so do a 1/4 turn and let it sit for a while, take temp and adjust again if needed.
Jun 16, 2012 | Southbend Kitchen Ranges
Oven is Electrically charged Or Uses LPG domestic Gas?.
GS460 is not the full model number for the range. The range needs both electrical power (120V AC) and gas. The electric power is used for the burner igniter and controlling the range thermostat.
The GS460LEK can be used with either NG or LPG. It came with the NG orifices installed at the factory; a conversion kit needs to be installed to use LPG. (The cap in the regulator also needs to be turned 180 degrees to read LP.) This should be done by a trained installer. Most Whirlpool ranges will have the conversion kit attached on the back of the range near the regulator. See the installation guide from Whirlpool for your model, try https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=m3wLp9EUOpUUfCAXtvB5kw%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
The installation guide for the GS460LEKQ0 is available at https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%208522956.pdf .
I hope this helps.
Mar 28, 2012 | Whirlpool GS460 Gas Kitchen Range
Converting fromTown Gas to LPG in gas cylinders
Hi
Thanks for using FixYa. If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker
Check to see if power is getting to the range/oven. If even a light won’t turn on then check for a blown fuse or tripped circuit breaker.
Main wiring
Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Ovens
Hello, I have a Soutbend cooker serial N° NX
Call Rick at Restaurant Parts and More. 1-888-814-1110
Be sure to have model and serial numbers to ensure the correct part.
Nov 18, 2009 | Southbend S560DD (Gas) Oven
Can use gas for my liquid porpane grill
Yes you can as long as your home uses LPG. You can not use 2 regulators. If your outside line is after your home regulator you need to eliminate the regulator on your grill. LPG products operate on 11" of water column, that's about 1/2" PSI.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Frigidaire FD26LPDC (LP) Grill
Want a manual for my oven
google your model # youl see lots of links
Dec 31, 2008 | Southbend 436D-2GR Gas Kitchen Range
Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Jan 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Southbend 436D-2GR Gas Kitchen Range Logo
420 people viewed this question
Top Southbend Kitchen Ranges Experts
Bill Boyd
Are you a Southbend Kitchen Range Expert? Answer questions, earn points and help others
