Question about HP Compaq dc7100 PC Desktop
Wont boot up with out hitting F1
When i boot my cp it tells me that 918 front usb not connected
917 audio not connected and they both are 512 chassis fsn not detected
  • Anonymous Jun 02, 2008
    918-front usb not connected
  • Anonymous Apr 06, 2009
    Sergeant:
  • 349 Answers
Check inside the case to see that nothing bad has happened to the cables connecting these items,also check the usb ports for any damage,go into device manager and search for new hardware,it may find them and install what it needs ,if all else fails, you might need to go get a bios upgrade , this may fix the problem.
after that and still have the problem, its most likely the motherboard
good luck
Terry
Posted on Mar 25, 2008
Error 918 front sub not connected Hp 7600 mini tower I added a 9 in 1 memory card reader. It gave me this error so I reconnected the original front usb then after start up I unpluged it and connected my...
wrong reader or plugged in wrong
Bios scans it and if missing or connected wrong, or wrong reader
then 918 trips, but the PC run good , just ignore the boot error
the other 2 errors on mine are 917 fron audio and 512 rear fan bad.
but runs till the cows come home.
next time post the HP model number of the panel
918 f_usb
917 f_audio. missing.
May 08, 2017 | Office Equipment & Supplies
Xw 4600 917-front audio not conntect
old post , error 917, sure, all do that when....
P23 wired cable fell off(or loose, its keyed)
or wrong panel used, (hp makes many , only 1 works here)
the offical, service manual covers all POST errors
and is still free, to see at real HP at any time.
Hit F1 and PC will boot ok, even with that error.
see p23 here.... front_audio jack, bottom left mobo.
http://www.pcdied.com/intel-magic/xw4600.html
Apr 22, 2014 | HP xw6600 Workstation with 650W 80 PLUS...
Audio wiring problem on HP Compaq DC7100 CMT with DC7700 motherboard
You have a problem with HP connectivity. When I moved my dx7100 motherbard into another casing I experienced that error and also chassis fan not detected error. Chassis fan error is easy to remove, You only need a fan with at least 3 cables (with sensor) and plug it into 4 pin chassis fan connector. Audio conector have 10 pins (eight pin missing for orientation (with followed numerication
2 4 6 10
1 3 5 7 9
If you only want to get rid of the error ( with no use of back audio(use of another soundcard)) then short pins 2 and 7. But if you want to use back connectors, then you must bridge with jumpers 1-3 for microfone, 5-6 for audio L and 9-10 for audio R.
I've bee searched thru internet and didn't find this trick anywere.
Feb 24, 2013 | HP Compaq dc7600 Convertible Minitower PC...
How to resolve that chassis fan is not detected
HI
CHECK YOU FAN IS REALY CONNECTED OR NOT
IF SHE DOEn't WORD REPLACE YOUR FAN
Feb 18, 2012 | HP Computers & Internet
917-Front Audio Not Connected
Please connect front audio cable with motherboard in the a audio port of motherboard.If we work with sound card then connect front audio cable with sound card.
Feb 12, 2011 | HP Compaq dc7100 PC Desktop
WHEN BOARD BOOTS ERROR 512 - CHASIS FAN NOT DETECTED APPEAR LET ME KNOW HOW TO DISABLE THIS ERROR it does it every time i start, or restart the computer, and i have to hit F1 to get it to boot, what...
hi this is a setting in the bios/ cmos you have to press either del or f2 to enter the menu, when in the menu look for a setting that will disable the chassis fan speed do this when booting up...hope this helps
Jan 14, 2011 | HP Compaq d530 SFF PC Desktop
hi this is a setting in the cmos or bios you have to hit delete key or F2 depending on make of system to get into the menu, locate the setting for the chassis fan speed then disable that and you should not see the error on boot again...hope this helps
Jan 14, 2011 | Computers & Internet
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
By enforcing the option to return BACK TO THE LAST KNOWN GOOD CONFIGURATION you have nothing to lose. Respond if you have already selected that option with no success?
Bruce
Jan 12, 2011 | HP Computers & Internet
I need codes for tv for philips universal remote
Here are codes for Universal Philips Remotes for Televisions. Directions at the bottom to enter codes.. Good Luck!
ABEX ................................. 120
ADMIRAL ................. 701 918
ADVENTURA .................. 019
AIKO ................................. 407
ALLERON ........................ 206
AMARK............................. 603
AMTRON.......................... 906
AKAI ................................. 801
AMSTRAD ........................ 520
ANAM NATIONAL .104 805 901 906 920
AOC ............ 002 003 102 119 217 302 502 814
ARCHER ........................... 603
AUDIOVOX ...................... 906
BANG & OLUFSEN ......... 620
BELCOR ............................ 002
BELL & HOWELL .......... 506 601 701
BRADFORD ...................... 906
BROKSONIC .............. 215 316
BROKWOOD.................... 002
CANDLE .... 002 019 402 502
CAPEHART ...................... 119
CELEBRITY ..................... 801
CENTURION.................... 502
CETRONIC ....................... 805
CITIZEN .... 002 112 402 407 502 512 701 805 906 319
CLAIRTONE .................... 003
CLASSIC ............................ 805
CLP .................................... 016
CLP CLASSIC .... 013 012 001
COLORTYME ... 002 502 602
CONCERTO ............... 002 502
CONCIERGE ..................... 713
CONTEC/CONY .......003 802 805 902 906
CRAIG.........................805 906
CROWN......................805 906
CURTIS MATHES ............ 002 103 112 502 506 512 601 701 704
CXC ............................. 805 906
DAEWOO .. 002 102 110 214 303 311 314 403 407 502 503 611 805 809 909
DAYTRON................. 002 502
DIMENSIA ................. 601 704
DUMONT .................. 002 713
DYNASTY ........................ 805
ELEKTRA ........................ 701
ELECTROBAND ...... 003 801
ELECTROHOME ..... 002 502 803 901 914
EMERSON . 002 003 004 005 104 105 106 115 204 205 206 213 304 305 316 319 405 502 505 506 519 604 605 705 804 805 903 904 905 906
ENVISION ..................002 502
FISHER ....... 506 606 619 902
FUJITSU ............................ 206
FUNAI ................ 206 805 906
FUTURETEC ............805 906
GE ........ 002 006 007 018 107 114 310 312 502 601 704 719 803 806 810 901 911
GIBRALTER .............. 002 713
GOLDSTAR 002 102 117 207 217 307 502 818 914
GRUNDY ....................206 906
HALLMARK .............002 502
HARVARD ......................... 906
HITACHI .... 002 016 116 216 315 502 507 515 519 607 615 701 707 715 815 902 915
IMA .................................... 906
INFINITY ......................... 807
INTEQ ............................... 713
JANEIL .............................. 019
JBL ..................................... 807
JCB ..................................... 801
JC PENNY ......... 002 007 102 107 112 310 312 402 502 512 601 704 719 803 806 818 907
JENSEN ......................002 502
JVC ...................... 007 107 108 308 510 607 902
KAWASHO ......... 002 502 801
KAYPANI .......................... 119
KEC .................................... 805
KENWOOD ....... 002 502 914
KLOSS NOVABEAM ....... 019 408 508
KONKA .............. 203 208 219 306 317 417
KTV .................... 003 213 319 608 703 805 906
LODGENET .............. 601 701
LOEWE ............................. 807
LOGIK ........................601 701
LUXMAN...................002 502
LXI .............. 002 312 502 506 512 601 704 719 807
MAGNAVOX ..... 002 009 109 118 209 309 402 408
502 508 510 807 914 917
MAJESTIC ................. 601 701
MARANTZ ........ 002 502 807
MATSUI ............................ 807
MEGATRON ...... 002 502 507
MEI .................................... 003
MEMOREX 002 115 206 502 506 601 701 706
MGA.................... 002 102 206 502 619 803 914
MIDLAND ......... 007 107 312 713 719 818
MINUTZ ........................... 806
MITSUBISHI .............002 102 206 502 510 619 709 803 814 914
MONTGOMERY WARD 601 701
MOTOROLA .............901 918
MTC.................... 002 003 102 112 502 512
MULTITECH ................... 906
MULTIVISION ................. 010
NAD ............ 002 120 502 512
NEC ............. 002 102 110 111 502 510 602 901
NIKEI ................................ 805
NIKKO ............... 002 407 502
NTC ................................... 407
ONKING ............................ 805
ONWA ........................ 805 906
OPTIMUS .................. 120 618
OPTONICA ............... 111 918
ORION ................ 105 115 713
PANASONIC ...... 007 107 516 608 618 718 807 901
PHILCO ...... 002 009 102 109 309 402 408 502 508 807 901 914
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
PILOT .............................. 002
PIONEER ...................002 120 502 519 610
PORTLAND.................002 102 407 502
PRECISION ....................... 218
PRICE CLUB .................... 112
PRISM ................................ 107
PROSCAN ......... 312 601 704 719
PROTON .................... 002 119 220 502 910
PULSAR ............................ 713
PULSER ............................. 002
QUASAR .... 007 107 516 608 618 718 807 901
RADIO SHACK/REALISTIC ......... 002 111 117 406 502 506 601 618 704 705 805 818 906 914
RCA ..... 002 011 102 211 302 312 318 320 406 409 411
420 502 511 514 519 601 702 711 719 809 811 901 909 911 912 914
RHAPSODY ..................... 003
RUNCO .............................. 713
SAMPO ....... 002 119 502 818
SAMSUNG .. 002 012 102 103 112 212 502 512 818 914
SAMSUX ........................... 502
SANSUI ....................... 115 215
SANYO ............002 412 506 619 902
SCOTCH ..................... 002 502
SCOTT ............... 002 004 105 206 502 805 906
SEARS ............... 002 112 206 312 502 506 512 520 601 612 619 704 719 902 914
SHARP 002 013 014 111 502 712 812 813 913 918
SHOGUN ........................... 002
SIGNATURE ...... 601 701 903
SIMPSON .......................... 402
SONIC ................................ 003
SONY .................. 202 708 801
SOUNDESIGN ... 002 206 402 502 805 906
SPECTRAVISION ............ 921
SQUAREVIEW ................. 520
SSS ....................... 002 805 906
STARLITE ........................ 906
SUPREMACY ................... 019
SUPREME ......................... 801
SYLVANIA . 002 009 109 209 309 402 408 502 508 717 807 914 917
SYMPHONIC..... 520 904 906
TANDY ............................. 918
TATUNG ........................... 901
TECHNICS ................. 007 107
TECHWOOD.............002 007 107 502
TEKNIKA .. 002 019 102 112 206 209 402 407 502 512 601 618 701 805 902 906
TELECAPTION .............. 313
TELERENT ............... 601 701
TERA .......................... 002 220
TMK ........................... 002 502
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
VICTOR ............................. 607
VIDTECH........... 002 102 502
VIKING .............................. 019
WARDS ....... 002 004 009 102 109 111 206 209 310
408 502 508 513 601 701 704 806 807 914
WHITE WESTINGHOUSE ... 311 611
YAMAHA... 002 102 502 914
YUPITERU....................... 805
ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
Nov 18, 2010 | Philips Televison & Video
HP Compaq dc7100 PC Desktop Logo
3,656 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
