Question about Kenmore 24052 Top Load Washer
Kenmore model 24054 washer that leaves dark streaks on clothes.
I have a Kenmore model 24054 washer that leaves dark streaks on clothes. I assume it is coming from detergent/grime under the agitator. How do you remove the agitator to clean underneath it?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to access the console, pull the cabinet, agitator(s) and tub if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=ef7d852e2285d2944a8b015a847b15db
You don't have to pull the pump, motor, transmission and drive tube to pull the agitator and tub.
HOWEVER:
A number of the diagnostics and repair procedures for these washers require you to remove the agitator(s).
In order to get the agitators out, you need to remove the "Spanner Nut" and "Drive Block".
Many instructions call for a special spanner wrench to remove the nut. However,
You don't need a special spanner wrench. (About $20 retail)
I've used a short 10" pipe wrench (About $9 also good for cracking walnuts) hooked around one of the tabs on the spanner
nut and tapped the handle with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
With the agitators and tub out, it's relatively easy to clean out the gunk that builds up over time.
Posted on Apr 26, 2010
My Kenmore Elite Top-Load Series 700 Washer leaves streaks on clothing. It looks like dusty powder. I use liquid HE detergent. It was a normal cycle of dark clothes, not heavily soiled or dirty. Also
THE stains on your clothing especially on whites are most likely due to a top seal failure on your transmission. transmission leaking oil. if the clothing affected or the stain can be removed with a solvent like gas, kerosene, paint thinner repair on washer will exed the value .... if the streaks or stains can be removed with a water soluble detergent then the stains are caused by the soap and or hard water deposits in your washer . then the solution to cut way down on soap usage in your washer and or running an acid wash (soap is alkaline acid will dissolve it . make sure not to over solvent your clothes and to rinse all solvents out completely . be careful !!!! a solvent soaked t-shirt bunched up and left in tightly sealed plastic bag WILL CATCH ON FIRE!!!!
Jan 22, 2015 | Kenmore Washing Machines
Why do i get white streaks on dark clothes
Well if you use dry detergent than dry using a lighter duty liquid detergent, and be sure to buy the right kind. If your machine is high efficiency the get the h.e. approved detergent.
Apr 20, 2013 | General Electric Washing Machines
I'm getting small orange spots/stains on my clothing after washing them in my Maytag washing machine. it is a 2010 machine too. Any thoughts as to what could be causing the stains?
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Jan 10, 2011 | Maytag Centennial MTW5800TW Top Load...
My Kenmore 22642 washer is leaving lint all over the clothes. If i run them through the dryer, that will remove the lint... but some of my clothes don't go through the dryer. I can't seem to determine if...
Wash clothes separately whites and light colors together. Darks with liquid detergent. No lint filter on the machine. I have found some powder detergents do not dissolve completely.
Dec 26, 2010 | Kenmore 22642 Top Load Washer
I get dirty streaks on cloths during the wash cycle.
It's a common problem with modern machines.
Due the modern way of washing on low temperatures some dirt will stick into the machine's.
You can try to wash some old stuff several times on a high temperature and instead of using washingpowder you have to use a handfull of soda.
It will clean the inside. Worked fine overhere.
Good luck,
Gerard
Jan 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
There are streaks (lint?) left on clothes after
It is not on the machine, it is on the detergent that you are using and the amount of water for per grams of detergent, maybe you are putting to much detergent, try to lessen the detergent and more water instead.
Nov 06, 2009 | Kenmore Washing Machines
White streaks on dark clothes after washing.
Reduce the load !!
You are getting white streaks because the clothes are so compressed the machine is not agitating them correctly.
My daughter gets the same problem and she still insists on packing the clothes in.
My wife washes the same clothes for her with the right load and they come out fine
Jun 18, 2009 | AEG Lavamat 88840 Front Load Washer
Kenmore washer leaves dark streaks on light colored clothes
I suggest you first take a clean, white cloth wetted with a stronger solvent such as 'Oops,' carburator or brake cleaner (with these two, DON"T overspray, they will damage plastic and paint) and wipe the drum inside to make sure there is not some gunk adhering that is gradually depositing itself with each wash cycle.
If you have a shade-tree mechanic in the family, they may have gotten a gob of grease on clothing that transfered to the inside of your machine.
If you don't find enough on the cloth to have caused the problem, I think you have lost a seal on the drum-side of the transmission.
Jul 01, 2008 | Kenmore 43042 Front Load Washer
Kenmore 44102 has stopped sudsing
Nancy this is a hard one. The first thing I would do is check how hard your water is. The harder the incoming water, the less suds. I believe your model starts with a 417. front loader and I assume that the detergent is being dissolved in the disp. tray. On this model, most of the water will be under the basket while agitating. Now, your drain from the tub has a filter and if it full of lint and debris, it could be restricting the drain, leaving dirty water in the tub. You would have to remove the lower panel and check the tub filter. This is located in the tubing coming down from the tub going to the trap and pump. I will attach a photo for you. You can also run the washer empty with hot water. Add 2 cups of bleach. After it starts agitating, stop it and let it sit for 2 hours. Then resume the wash and let it finish. See if the dirty smell goes away. Catriver..post back
Mar 19, 2007 | Kenmore 44102 Front Load Washer
Kenmore 24052 Top Load Washer Logo
113 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
