Question about Car Audio & Video
I have a jensen A600HLX the ground wire that goes on the board when i open it, it was screwed down between Q17 and Q16, Q17 was vaporized so i replaced it . where does that ground wire really supposed to screw to?
  • patrico_777 Apr 26, 2010
    thank you that was helpfull sorry it took so long thank man
  • 1,869 Answers
The wire goes to the tab marked "cold ground" or, if you can't find this: use a multimeter set to "ohms" and, put one probe on the chassis and, then: with power removed; look for ground on the board. (full continuity) between the frame and, "board ground" find the reason why Q16 and, Q17 failed as, this indicates a power supply problem that must be fixed first before you power the unit, or, Q16 and, Q17 will put on a fireworks show again.
Posted on Apr 25, 2010
How should i run my Jensen A600HLX Amplifier if i am using it to power 2 10inch Rockford P1 Subwoofers?
U need to check the impedance of your woofers .If they are 4 ohm i would reccomend hooking them in series, which is the positive output of your amp will go to the positive of one woofer, the negative of that woofer goes to the positive of your other woofer and the negative goes to the negative output of the amp.If that amp is bridgeable this will give u a good bass and the impedance will be 8 ohm so your amp will run cool and stable
Jul 30, 2010 | Jensen A600HLX Car Audio Amplifier
My sub is making a humming sound
Hey austinpippen,
The noise you are experiencing is due to your rca plug shorting out causing a loop, in outher words, bad earth.
Try getting a noise filter, you take your rca plug and plug it into the noise filter, then wire it to the amp!
you can try a ground loop isolator or relocating your ground [earth].
I hope this helps you out.
Fingers crossed.
Apr 08, 2009 | Jensen A600HLX Car Audio Amplifier
I got it smoking
it would be cheaper and smarter to buy a new one
Nov 25, 2008 | Jensen A600HLX Car Audio Amplifier
Grond Wire
You should be able to use any screw that goes into a metal part of the car to ground it. Simply grounding that wire may not work with the Jensen (it didn't on mine).
During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 13, 2008 | Car Audio & Video
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
Help
No. The amplifier gets its signal from the RCAs connected to the "input" jacks, but the "output" jacks are just there to make it easier to add another amplifier. You only need to connect the inputs for the amp to work.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
Need Help
input and output slots???? is it playing although thump present,low current could be the problem check for good connections as well as adequate wire guage.
Jensen A600HLX
check pwm ic 494 or other
Dec 16, 2006 | Jensen A600HLX Car Audio Amplifier
Jensen A600HLX
These solid state amps have no user serviceable parts inside them as everything is soldered into place and your gonna need to know how to use a multimeter to trouble shoot the parts inside the amp on the printed circuit board. Sorry But without the proper training and the right tools you could cause more damage to the amp if you dont know what your doing. You cannot just open the unit and see whats bad. You must test each suspected bad part and replace it as needed. You should take the amp in to have a pro look at it, as there is no easy fix on these unless its an external fuse, and a fuse will very rarely blow all by itself. Good Luck
Jul 17, 2006 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
