Question about Simplicity Denim Star SW210
Problem with the foot and feeder
So im pretty new at sewing but i got this product and its pretty good but the foot (the part that holds the fabric down when your sewing) is really jiggly when it is not down. also i "propeller" under the fabric that is suppose to make it move doesnt do anything. So i have to pull my stuff through verses it feeding it to me. also i los tthe manual so that just makes this harder.
  • lktahoe4two May 11, 2010
    Can't you spell? Proof read you response for errors
    Very hard to understand incorrect spelled words.
  • 3 Answers
You can also check the pressure foot regulator (near were the light is open the cover as if you were threading neelde and it is in there its mealat and has numbers 0-3 on it. 1 is for heavy fabrics, 2 for med, 3 is for light and 0 is for darning or fre motion sewing. the standard setting is 2. try both this and the feed daos, one of them should work.
michelle NH
Posted on Apr 08, 2008
The tention is not holding the material in place slips around when im sewing .
Do you guide the material with your hands while sewing?
Jul 07, 2015 | Sewing Machines
My stitch regulator will not work. I have had it looked at 2x but still will not change from 2.5 higher or lower.
What Viking is it ? Have you cleaned between the feeders? If all is clean, try this test. Remove needle. Turn hand wheel so that feeders are up. Put fabric in machine. Lower presser foot. Make sure presser foot pressure is set at normal. Try pulling the fabric towards the front of the machine. It should be hard to pull. If it is easy to pull you need new feeders. They are worn down.
May 01, 2015 | Husqvarna Rose
I have a Juki8700 it does not seem to be feeding the fabric thru on the feed dog
ck presser foot tension. even with sightest presser ft tension goods should feed. next ck that your feeder plate is not loose or broken. take off the plate and see if u can move the feeders with your finger. tighten screws makinf sure the needle is centered inthe feeder plate hole. if this is not the problen then youe=r feeder plate teeth are too low or worn out. look up how to raise the feeders. the should be 1/8" above plate.
Jul 25, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Uneven feed
machines can have single or double feeders. what type does yours have? feeding problems can usually be fixed by a good cleaning+ oiling of the feeder mechanism which regularly gets clogged with lint+threads/scrap threads. brush it out thoroughly with a stiff-bristled brush like an acid brush. apply 1 drop of oil to each feeder seen on the foot-plate. wipe excess oil off with a clean dry rag being sure not to get any debris from the rag caught in the feeder(s). other problem might be your bobbin tension. this is usually adjusted on the bobbin race with a very small screwdriver.
Feb 22, 2014 | Brother PC-420
Hyundai 8 stitch sewing machine confused beginner!?????
Not familiar with your machine, but an important suggestion for all sewing machines:
ALWAYS RAISE the presser foot when threading the top thread. If you did not do this, remove the top thread completely from the machine and start over by RAISING the presser foot and following the thread path. (Do NOT miss any thread guides or thread any out of order!)
Lower the presser foot and thread the needle. (The top thread will pull through the needle ONLY if the presser foot is raised!) RAISE the presser foot and pull at least 5 inches of thread through the needle. Insert your fabric. Lower the presser foot. Hold the thread tail gently in your left hand and with the right hand manually turn the handwheel one rotation. The needle should pull the bobbin thread up through the fabric.
While still holding the top thread tail, "sweep" under the presser foot with a stiletto, scissors, a nail file (anything that will fit under the presser foot) to pull the remaining bobbin thread tail above the fabric. Grab both thread tails and pull them under the presser foot toward the back of the machine. Now, you are ready to take your first stitch.
You can gently hold those thread tails while you slowly power the machine to take the first couple of stitches on your fabric.
Jun 27, 2017 | Sewing Machines
Fabric quit feeding through
there called feed dogs & if they don't feed the fabric thur the machine need they need to be check to see whats wrong with them
Mar 07, 2012 | Singer 3116 Simple
My janome machine sews on the same spot, the material does not move. I have moved the feeder foot but nothing happens.Sometimes the feeder foot stays down.Idont have a manual for this machine.Igot it as a...
the feed dogs in the needle plate area are what moves the fabric while the presser foot hold the fabric
if the feed dogs are not up, check to see what position are in,,they should be in the bobbin area
if you can't move them they should be checked at a repair shop
Nov 20, 2010 | Janome Sewing Machines
The thread bunches up underneath the fabric and then the machine stops after about 3/4 " of running. IM sure there is a simple solution, but I dont know what.
Refer to the maintenance section of your manual for cleaning the machine.
Always thread a sewing machine with the presser foot up.
Check the needle to be sure the flat side of the needle shaft faces the back of the machine.
Check the bobbin to be sure the thread is feeding in the correct direction and though the proper guides.
Using the handwheel, lower the threaded needle, holding onto the the end of the thread and then raise to pull up the bobbin thread.
Take both threads under the presser foot and to the back of the sewing machine.
Place the fabric under the presser foot and while holding onto both threads, lower the needle into the fabric by turning the handwheel by hand and create one stitch.
Let go of the threads and press on the power pedal.
If this does not resolve the issue, the machine may need the timing adjusted and this needs to be done in a shop by an authorized Singer tech.
If the machine is new, the warranty may cover the adjustment.
Apr 02, 2010 | Singer 2250 Tradition
Feeder feet under presser foot clicked down not able to get back
The switch for the FEED DOGS is on the left side of the machine.
Mar 19, 2009 | Kenmore 15343
Propeler foot
I'm pretty new to sewing as well, but have you checked to see if your feed dogs are up or down? If I am correct (little teeth on the sewing plate right under the needle)they are what moves the fabric along for you. If youre free sewing or quilting you'd want them down but not for regular sewing.
Mar 24, 2008 | Simplicity Denim Star SW210
Simplicity Denim Star SW210 Logo
120 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
