Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Have crafstman riding lawn mower: replaced battery, ignition switch, solenoid, and spark plug but it still will not crank and start up. what is the problem?
  • 86 Answers
Double check the ground wire going from the battery terminal to the engine...it is usually on a mount bolt at the engine...if the mount bolt is loose, it's a poor connection...
Posted on Apr 26, 2010
Why won't my riding lawn mower crank over?
Hi if you have got it cranking remove the plug and check for a spark the plug must be earthed to do this if you have a spark it must be fuel pore a small amount in top of carb make sure ign is switch on hope this helps.Ron.
Jun 20, 2014 | Craftsman 420cc 30 6-Speed Rear Engine...
I have a cub cadet lt104 and we replaced the battery and solenoid and it won't start
wont crank or wont start. 2 different things...
wont crank, in this order: check fuse, brake switch ( adjustment and operation ) and then ignition switch
wont start but does crank: check for spark, yes then check fuel shut off solenoid. no, disconnect kill wire to coil and check again, still no, coil is issue, if yes after disconnecting kill wire suspect a safety switch
May 16, 2014 | Yard Machines 155 Torque Briggs Stratton...
Can the overhead valves on a 16hp sears craftsman with a kohler engine be the reason why it won't start and if so, can I adjust them
Valve clearances will also effect the decompression valve in the engine, if they are too wide the valve lifter will not work and the battary will not have enough energy to crack the engine.
Jun 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Ranch king riding lawn mower ignition problems check switch solenoid and battery now what?
If you have checked for spark at the plug end of the ignition lead and don't have one when cranking, the ignition coil has probably failed. Checking this part will require some disassembly of the mower and then the engine. I'm afraid these are all Chinese made coils now (cheap, cheap, cheap) and are common failures in most small engines.
Jun 17, 2011 | Mtd Garden
I HAVE A POULAN MOWER TRACTOR MODEL HD12538B THAT WILL NOT CRANK. I HAVE JUMPED THE BATTERY WITH THE CAR, REPLACED THE SOLENOID AND THE IGNITION SWITCH. i HAVE ALSO JUMPED THE STARTER AND IT WILL CRANK...
Try replacing your spark plugs. Make sure its getting gas. Make sure your air filter is nice and clean. Check your fuel filter. and if all those fail try replacing your coil.
Feb 07, 2011 | Poulan Garden
Attempted to start poulan lawn tractor, it begin to turn the engine over but immediately stopped cranking and the battery was making a fizzling noise. I installed a new battery and when connecting the...
Most likely you have a short in the ignition (key) switch. Disconnect the battery first! Then look at the wires behind the ignition switch for burned or missing insulation. If all that looks OK, I would replace the ignition switch. It is also possible that your solenoid/starter assembly has failed and the solenoid has stuck in the 'on' position; but that will cost more to replace so I wouldn't start there.
Aug 16, 2010 | Garden
Crafstman lawn rider 42" turn off after run for 2 minutes
sounds like your coil is getting hot and shutting down,, cool off and run for a while more,, coil is located next to the fly wheel,, just follow your spark plug wire and you find it,,,good luck
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Run out of things to check
coil{solid sate ingnition) see if u hav spark ground plug,low light {shade} to see spark,AWAY FROM BUILDING and GAS!! hav fire extinguisher handy..remove all ignitable fuilds,well ventilated area..if spark,check "kill" switches on throttle,clutch pedal and seat.
Aug 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cant get my lawn tractor to start
IT COULD BE IGNITION SWITCH IS BAD, I REPLACED ONE ON A CRAFTSMAN THAT DID THIS,BUT ALSO COULD BE A SAFETY SWITCH IS NOT CLOSED PREVENTING STARTER FROM OPERATING,---WITH THE IGNITION SET TO ON CROSS THE TERMINALS ON SOLENOID AND SEE IF IT STARTS THE TRACTOR RUNNING, IF IT FAILS TO RUN ITS PROBALY THE IGNITION SWITCH THEN.
Apr 09, 2009 | Briggs & Stratton Garden
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
172 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
