Question about Sony Video Game Consoles & Games
Hi I have a PS2 full size and the 4 pin link wire for the reset eject botton pulled out during cleaning. Where does the wire plug into.
    Guru:
  • 229 Answers
Take your time to watch this video and u will be okay.just follow the link below.
http://www.youtube.com/watch?v=HdMgd0y3DIg
Posted on Jul 13, 2010
Shell does not eject slide jams..I pull clip, pull slide back a couple times , shell ejects what is my problem
Hi! Kevin.....bit hard to know !....assuming ammo is correct dimensionally & of good power., & extractor & ejector are in order & chamber is good & slide is free & full sliding......then my first guess would be sticky firing pin not retracting properly thus stymying ejector action.......any stickier & you might get full auto ?......are you puncturing primers ?.. if gas back escape is part of the picture , bullet may not leave barrel . I suggest you do full strip , incl firing pin , clean & remove any burrs ..... worthwhile to run some dummies by hand & see how they behave..........jimbanjo
Jan 16, 2014 | Smith & Wesson SWW-357-R
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Loose wire in the PS2
It is located on the right side, underneath the CD Drive.
Nov 27, 2008 | Sony PlayStation 2 (PS2) Console
Disc tray???
Did you recently open the ps2/modify it?
Found this which may help (and will void your warrenty):
When you take the top cover off of the PS2, you can see where the Reset/Eject ribbon cable plugs into the system itself. Right next to and slightly below here are three wires with three tiny color-coded plug-ins attached. They are just pressed into place and have a tendency to work themselves out over time. And depending on which one came undone, the disc tray will either always want to stay closed or always want to stay open. Either way, the operation of the disc tray will be erratic and problematic.
So it's a matter of using a pair of needle-nosed pliers to grasp and make sure that all three of these tiny plug-ins are fully inserted into the slots where they belong. Sometimes it's even necessary to very slightly lift the PS2 out of the bottom half of it's shell to gain better access to them. After they're all clearly in place, then it's a good idea to use the same needle-nosed pliers to make sure that the ribbon cable did not slightly pull out of place from where it is plugged in as well, or the Reset/Eject buttons will not work.
After all this, you can put the PS2 back together and voila...you should be good to go!
Sep 06, 2008 | Sony PlayStation 2 (PS2) Console
My old playstation 2
I would take it to a computer fixing place and see if they can fix it
May 16, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Controller Wiring Diagram
heres the diagram
http://www.curiousinventor.com/guides/ps2
Dec 09, 2007 | Sony PS2 Dual Shock 2 Controller...
PS2 power ribbon
Hi Anishpp
If it came loose from the buttons, you need to remove the button holder to get to the connector. Push he ribbon into the slot on the back of the buttons.
If it came loose from the motherboard, you will have to remove the guts of the PS2 to see the connector under the cd drive right side. This is done by removing 4 screws. Two are on either side of your Controller ports. Another one is located between the fan and power block. Another is to the left of the powerblock. lift the guts from the back and pull the system out. looking at the right side, plug the reset Eject ribbon into the 2nd connector from the front. Then put it all back together carefully.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
Eject/reset cable
You need to use a pair of needle nose pliers and grip the ribbon cable by the stiff plastic strip and plug it into the second connector from the front that I believe is White. These connectors are near where the Reset Eject button locates. Check out my website www.playstationclinic.com
Sep 23, 2007 | Sony PlayStation 2 (PS2) Console
Loss of power to onboard USB and PS2 ports
Hi, I checked a known good spare motherboard with a VOM (continuity tester): pin 4 of the KB PS2 port, pin 1 of the rear USB, pin 1 & 2 of the front panel USB onboard connector, pin 3 of the infrared, pin 4 of the speaker connector, pins 4, 6,21 & 22 of the ATX 24-pin Power Connector are all interconnected (+5VDC). If that is an indication of the general +5 supply layout, you can probably hard wire a new +5 supply line to where the +5 is gone from where it is still available. Of course without a schematic, I might be off. Determining the actual component position of the surface mounted fuse (or fusible link) might not be that easy since manufacturer do not publish such information loosely. A shotgun approach (test all) would be time consuming but of course challenging. Your best bet would probably be as mentioned earlier, hardwire and install in series with the new +5 line a low amp (500ma or lower) smfuse. This article describes the power requirement of USB ports > http://pinouts.ru/Slots/USB_pinout.shtml. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 18, 2007 | MSI MBOX PM8M2-V (MBOXPM8M2V) Barebone
Video Game Consoles & Games Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
