Question about Weber Genesis Silver B Grill
The back burner doesnt consistently light up.
My front one works great, but the flame doesnt ignite all the way around. also, my temp doesnt really get above 350...am i missing something? thanks for any help you can provide.
    Guru:
  • 1,051 Answers
If the flame doesn't go completely around the burner, ther is an obstruction at the outlet holes. Make sure all outlet are clear of dirt, rust,or any material. Even water will block the outlets.
Posted on Apr 26, 2010
  • 494 Answers
It's also possible you are not getting enough pressure to burn both burners at the same time. If your gas regulator can be adjusted, remove the center cap and turn the set screw clockwise to increase pressure. Turn it in quarter turns and check for desired flame size. Also make sure your air shutter adjustment on your burner is set properly. Compare it with the air shutter on the working burner and adjust accordingly.
Posted on May 15, 2010
A.o. Smith gpsh 50 103 tries to light after third attempt shuts down.power down blow air into burner area after cleaning igniter assembly will light usual on first try sometimes second time
The flame arrester are dirty. you can remove burner assembly and blow air back down flame arrester. You will need high temp sealant to seal burner assembly back to prevent flames from coming out the mating surfaces.Raise the heater off the floor. Probably best to change unit. keep floor clean around unit.
Apr 12, 2018 | Smith Computers & Internet
Burner ignites but shuts off as ignighter shuts off
Sounds like the flame sensor, located in front of the burners, usually to the left. Its a small bar that detects the flame when the burners are on. Most times, you can take it out and clean off the oxidation with a light abrasive material to get it to work. If that does not work, I would need a little more information to continue. Hope this helps!
Nov 20, 2012 | Honeywell Heating & Cooling
Viking gas oven model # VGIC3656BSS, serial #022404-2919 takes FOREVER to preheat up. Sometimes in excess of 40 minutes. Been a problem for a while. Looks like flames at bottom do not increase when oven...
When increasing the temp. on a gas range the oven's burners do not increase flame size as the cooktop burners do. It just keeps the burner lighted for a longer amount of time.
First if you can see the burners do they light within about a min. or less. If no you probably have bad igniters which are not lighting the burners as quickly as they should or they are "opening up" (stops working) when they get too hot. In this case replacement of the igniters should solve the problem.
Second if it lights quickly but still takes a while to heat; you want to look at the burners to ensure that the flames are down both sides of the burner tube and not dancing around too much. If only part of the two sides of the burner tubes are lighted then a pluged orifice or burner tube is the most likely cause. Once cleaned it should work fine.
As with anything mechanical there are numurous possiblities for something not working correctly and above are the two most popular reasons that come to my mind.
May 17, 2011 | Viking VGRC485-6 Gas Kitchen Range
Furnace cuts off before reaching set temp.
You can make sure it is not the thermostat by crossing or jumping the R and W terminals (or associated wires) together. This will keep the furnace calling for heat. As it is approaching set temperature, get in front of the furnace and inspect the air filter to make sure it is clean, watch the control module for any error codes that may be turning off the system prematurely.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 07, 2010 | Honeywell Programmable Thermostat Heater
VDSC 365-40, Suspected right side ignitor box bad. Repairman came, obviously didn't know Viking, tore into unit and confirmed bad ignitor box. Estimated $450 to repair. I put in new box myself. Works...
You have to identify the thermocouple by the flame. Some units run sparks constantly to insure that tha flame stays lit. If you see the thermocouple bulb by the flame it is bad and needs replaced (he may have bypassed it also let me know)
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m10110_viking_primer_2005.pdf
It would be helpful if you have a multi meter. Sorry you are having trouble with the repair man. I hope I can talk you through this but if he has made a mess it could be 10 times more work for you. Txtooltime@aol.com
Sep 02, 2009 | Viking 30" Professional Select Built-in...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas heater won't work
Which flame sensor did he replace? The pilot flame or the plenum temp. sensor.
Dec 14, 2008 | Carrier 38CKC036 Air Conditioner
Low flame on 3 main burners. model GBC730W
Mike, I had this problem with my grill once or twice. Like most of us grilling men we turn the grill off at the tank trying to be safe. Sometimes, like in my case, I do not turn the nobs back to the off position. When returning to the grill the next day or week the first thing we do is turn the gas on leaving the nobs on, then lighting. Every time I do this my flame never gets full or does not reach full temp. To resolve this: turn everything off including the nobs, then turn the gas on, wait a minute or two. Turn the nobs to full and ignite. It should be at full flame then, adjust from there. I hope this is helpfull.
Sep 23, 2008 | Grilling
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Hotpoint RGB745 Burner Problems- Unique, needs help
Not sure, but sounds like you may have a gas pressure problem or the stove is set-up for the wrong type of gas.
Apr 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Weber Genesis Silver B Grill Logo
308 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
