Question about Dell E152FP 15" Flat Panel LCD Monitor
I have a blue and white padlock keeps showing up in the middle of my screen. Blinks on and off for a while then disappears, then comes back. On and on, very irritating.
    Novelist:
  • 128 Answers
It sounds like the DELL Capslock indicator. It is a light blue square with a lock on it and a capitol A under the hasp. You may have a bad keyboard key. switch out keyboards and see what happens.
Good luck,
James.
If this was a help, PLEASE click on 4 thumbs up!!
Posted on Apr 25, 2010
I have a Panasonic HDTV that was made in July 2002 Model#-PT-61HX42F. The screen just went off and the power button keeps blinking 3 times then goes off and repeats but the picture will not come back on
3 blinks is short protection and usually means one of the 2.2 ohm blue resistors in front of the convergence IC chips is bad---the chips are black and 2 1/2 by 1 1/2 tall and should have STK392-110 on the front of them; locate them and look at all the (about 10) powder blue resistors in front of them----if you find one or more discolored or white in the middle the chips and the resistor needs to be replaced.
It can be a do it your self repair (I have start to finish instructions if you need them).
SD TECH
Jun 05, 2011 | Panasonic Televison & Video
When I turn on my laptop the loading process gets as far as the initial blue screen and stops there. The screen will have the loading white symbol in the middle but then that will disappear and instead of...
Try dumping the RAM. To do this press the power button and then hold "Command, Option, P, R" before the gray screen appears. Then the computer will 'bing' and restart. Wait until it has 'binged' twice then let go.
Feb 10, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
A line has appeared across the bottom of the screen and also along the middle. the bottom line is white/red.blue and the middle line is mainly green
If your TV is still under guarantee then change it asap, if not you have a problem, the panel has failed, in very rare cases the lines will disappear when the set is at its maximum operating temperature, that said it will never be 100% again, sorry
Apr 19, 2010 | Grundig GU26DVD 26 in. LCD TV/DVD Combo
When I turned on my computer, it said it was in power saving mode and to press any key or move the mouse. Did that. Now I have a black rectangle in the middle of my screen that says, "Positioning,...
Your Problem Is not in your Monitor Its in your CPU. Your CPU is not giving Display Signal to Monitor that's why Monitor goes to power saving mode. try to open Your CPU and remove RAM Clean RAM Slots and Fix it Again. Try to Boot now.
Mar 11, 2010 | Dell E172FPt 17" TFT LCD Flat Panel...
Red color keeps disapearing
check plug for bent pins.....
Dec 05, 2009 | eMachines T6420 PC Desktop
Padlock appears on screen
I have this monitor,got it used at the goodwill, padlock problem and the control buttons (eccept for power) did not work. I tried every solution posted with no success. Then I got brave, I dove into the problem. 1) remove base, four phillips head screws. 2) remove the back, five phillips head screws. one in each corner and one behind the base mount, thus the need to remove the base. 3) carefully pry off the back, it snaps on, so take your time. I found a butter knife to be very helpfull. 4) The buttons are sodered to an electrical board whitch is snapped into place so carefully pry up from one side,again I used a butter knife. The wires are sodered to the board, they do not unplug. 5) Using a can of air, blow into each button and trying to clean out the inside them. I'm sure they should probably be replaced but we do what we can. 6) Put it all back together. 7) plug it in and connect it to computer. start working the buttons, at first I thought it was a lost cause but after about a minute I was able to get into the menue, scroll down using the arrow buttons and turn the lock off. A $300 monitor for 40 bucks. I hope this message gets to you before you give up. GOOD LUCK, GMAN8773
Sep 05, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Problem with Poloroid LCD 32 in. TV
stiv0's Support Profile at FixYa will give you detailed instructions for repairing your set
Jan 15, 2009 | Polaroid FLM-3732 Television
Dell E152FP 15" Flat Panel LCD Monitor Logo
372 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
