Question about Canon PowerShot A530 Digital Camera
I bought the best rechargable batteries and it still has low batt
I bought the best rechargable batteries and I still bet the low battery warning.
  • Canon Master
  • 4,738 Answers
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info:
Posted on Apr 26, 2010
Nikon d40 low batt info but batt is full charged
sometime if the battery is dead it still shown fully charge on the charger, try change another battery or with new one.
Nov 07, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
I have the same problem, the batteries do not last. Just bought new high quality batteries and put them in. The camara is already showing low battery and turn's itself off (just after putting them in,...
this occurs in any device that uses battery/s in some cases a small short forms that drains the batts there is only two fixs have the fault found by a service tech and repaired ( expensive and very hard to find) or store the batts out of the camera untill its being used now if the batts are not lasting in the camera then its the batterys simple. always remember with units such as camers always always use rechargable batts they give a heck of a lot more power drive than shelff pre charged batts
merry christmas
sonic boom electronics australia
please take the time to rank this advice below
thanks
Dec 24, 2010 | Fuji FinePix S3000 Digital Camera
How can i check if which need replacement my batt or my charger coz when i charge my batt the led lights on then after a while it turn of the led light then ill unplug it and plug it then still the same...
Power Source Li-ion Rechargeable Battery (LI-42B) Are you using the above battery?
Check the voltage to make sure it has enough as printed on the charger or the battery.
Alkaline rechargeables, or NiMH rechargeables, or other types of batteries don't have enough voltage or amperage as compared to Li-ion.
Jul 03, 2010 | Olympus FE-280 Digital Camera
Battery Packs for Powerware 9355 UPS
The Batts can be charged externally, then refitted, usually I extend the DC cables so I can work with the batt outside the unit. This is ONLY to be done if you understand the risk and what may happen if you get it wrong.
Batts are always live and can cause fire/explosion/severe burns if shorted!
IF YOU ARE NOT SURE THEN GET SOME EXPERIENCED HELP!
OK so the UPS will not normally recognise a very low batt pack, that is the reason you can not start the test, this test will back of the rectifier so the batt pack takes the load for a short period.
If the batt pack is out of range then this will make the load go off, so the UPS is designed not to allow the test,unless the batt is at the right level.
If you can get the batt pack up close to normal then the unit will recharge it to full.,Wait until it is fully charged before testing.
If this is sucessful the cyle the batt a few times allowing it to reach around low batt warning before recharging. This will assist the batt in recovery. During this process if possible monitor with a test intrument(fluke 123 or 43B will do) the batt pack discharge curve , once the batt pack has dropped to its charge level from float, it should be a smooth decay.
depending on the state of the batts you may be ok, if there are weak ones in the string then you may have to replace all of them depending on the age of the batt pack.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Feb 03, 2010 | Powerware 9355 UPS System
Hi, I have a set of Hope Vision 2 lights running off the type 2241 2 cell Li-ion charger. Although I know the battery pack is low on power (lights giving warning flash) when I plug in to charge it only...
how many times have you recharge the batts some need to be run down completely to get the best out of them.. You might consider changing the batts as they could be taking charge but not holding it..
Aug 04, 2009 | Epic Hope Vision 2 Two Led Light Mtb...
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Low battery life
hey there I find I can use the cheapest batteries and they work fine in my digital camera only if I keep it on. as soon as I turn it off and back on it sucks the battery dry.
the Energizer 2300 seem to be the best of the best in the testing for batteries life.
here is a good read for you on a digital camera batterys
http://www.imaging-resource.com/ACCS/BATTS/BATTS.HTM
Aug 11, 2008 | Canon PowerShot A520 Digital Camera
New camera at Christmas. Low Battery always on. Using Energizer Rechargable 2500mAh. Third set of batteries.
try energizer lithium batts- some cameras very very strange about batterys-have a sony that will only work w/ sony or energizer lithium-bought all other types and they do not work-i get 300-500 pics per set of lithiums-good luck
May 13, 2008 | Cameras
Flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
Canon PowerShot A530 Digital Camera Logo
193 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
