Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Canon powershot a80 E18 lens comes out then goes right back in the camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 10, 2011
Solve e18 problem
E18 refers to a lens issue, the camera needs a new lens unit, or the lens repaired. Marginal repair now.
Jun 08, 2010 | Canon PowerShot A80 Digital Camera
Have Canon PowerShot A80. New batteries, turn on and it automatically turns off with a buzzing/clicking noise... Window shows error E18
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 40% of lens errors, but if the camera is out of warranty they're worth a try:
Nov 14, 2009 | Canon PowerShot A80 Digital Camera
My Canon Power Shot A80 Digital camera goes ON but only shows the screen name Canon then the lens goes back into off - some sounds come on and then E18 shows in the lower left of a black screen. Help.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 09, 2009 | Canon PowerShot A80 Digital Camera
My Canon PowerShot A80 Digital Camera on and then off
If the E18 error code comes along with unusual noises while moving the lens, there may be a problem with the mechanics. Just tap the camera on a solid surface a few times. I had the same problem and tapping helped just fine.
Mar 01, 2009 | Canon PowerShot A80 Digital Camera
Powershot A80 error E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 05, 2009 | Canon PowerShot A80 Digital Camera
E18 displayed on Powershot Canon A80
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Nov 02, 2008 | Canon PowerShot A80 Digital Camera
Canon powershot sd400 error code E18
Yes !! I wacked it a couple of times on a hard surface and it started working again after I dropped it and got the dreaded E18 error mesage in the middle of a Jewelry shoot. wm
Oct 14, 2008 | Canon PowerShot A80 Digital Camera
E18 Error
Sorry to hear that. I have an A80 also, and I really like that camera (swear it takes better pictures than even my A620).
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
May 11, 2008 | Canon PowerShot A80 Digital Camera
Unuseable Camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 05, 2008 | Canon PowerShot A80 Digital Camera
Help with code
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 05, 2007 | Canon PowerShot A80 Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
