Question about Maytag Neptune MDG5500AW Gas Dryer
Neptune gas dryer
When the dryer starts, it makes a loud thumping noise when it is turning. Sounds like somethin is loose.
  • 725 Answers
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Posted on Apr 05, 2008
SOURCE:
Maytag neptune dryer makes loud noise on the right side when top dryer is on
The belt tensioner bushing could be shot or there may be a piece missing from the belt. Did you check the back for a removable observation cover?
Jan 05, 2014 | Maytag Neptune MCE8000AY Electric Dryer
How do I open a Maytag Neptune Gas Dryer? It is making a loud noise as the drum turns. It sounds like a shoe in the dryer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 13, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer makes a loud sqeeling noise when its drying clothes our maytag neptune is a gas dryer thats about ten years old
heatman101
ghgh
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is making a loud banging noise.
there are bushings or rollers at the front of the drum that do wear out this will cause the thumping as it turns. A local appliance repair place may be able to source out new guides for you.
Feb 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The dryer is making a loud noise when running. the drum is turning. almost sounds like something is rolling around under the drum.
heatman101
6565ggf
Feb 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer making a thumping noise while drum turns, as if there were a tennis shoe in it, but there isn't? Ideas?
heatman101
Jan 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Lumpy drum noise
Did you remove the shipping bolts from the back of the machine
Mar 26, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune MDG5500AW Gas Dryer Logo
127 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
