Toshiba colours gone wrong
I have a Toshiba 32'' tv, standard tube type but only a few years old.
Lots of fuzzy line appeared but now the colours have one a bit funny....eg
Red is now green, peoples faces are blue, grass is ok still green! But strangely tv captions (which were blue I think) are now red.
Any idea what is wrong and is it repairable?
  • 59 Answers
Yes it is repairable. One of two things is wrong. The color wheel is going bad or the DMD board is going bad. These are the most common repairs needed for a Toshiba. I hope this will help.
Posted on Mar 23, 2008
MY 35IN COME ON PICTURE AND EVERYTHING WAIT 10 SECONDS AND GOES OFF 35IN TUBE ABOUT 15 YEARS OLD
There is likely something wrong with the tube itself. It could be a short that is only there when the line warms up (10 seconds is plenty considering the amount of power that runs through it) or the CRT has a crack.
If you want to continue with this type of TV there are quite a few reliable TV repair companies in almost every mid to large town around the US. If you don't want to invest in repairing a 15 year old TV (not a bad life span for electronics by the way) then you could very likely find a 32"-37" LCD TV at your local electronic store that is reasonably priced.
May 23, 2011 | RCA Televison & Video
I have a 6 year old 32" Toshiba tube .tv. I have
thir is somecondensers on the tv needs to be changed especialy on pwer supply and vertical circuit it is easy fault but needs technication,,,but first be sure thir is no floresent lamp common with the same supply of the set
Dec 23, 2010 | Toshiba 32A14 TV
Old sony tv gets a bright line in the middle of the screen
Well if this is a tube type, it can be attributed to vertical section. Cold solder on vertical IC, the vertical gone bad or some components on the vertical is at fault.
If your not on electronics better to have it check by a repairer.
Hope this helps.
Jan 18, 2010 | RCA F32650 32" TV
As of a few days ago, My TOSHIBA TV MOD.32AF43 has shown a faded image with many horizontal lines across the screen. My TV was purchased probably in the year 2003/2004. I have checked all wires/cables...
Yeah it can be fixed its ether dry soldering joints or a resistor it should cost you about 55 pounds to fiix with most reputable tv repair people
Nov 27, 2009 | Toshiba 32AF43 32" TV
Toshiba 32" Model# 32A33 TV About 5 years old
change tact switches
you have windex syndrom
using too much windex cleaning tube
Aug 26, 2009 | Toshiba 32A33 32" TV
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Picture fuzzy
I would suggest to unplug the tv from the wall for about 15 minutes and then plug it back in,and turn it on,this should reset the microprocessor and realign the colors back to normal.let Us know how it goes and if you need more help.
Oct 12, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
