Question about Lexmark X5650 All-in-One InkJet Printer
Lexmark X5650 printer
How do I clear a carrier paper jam on a lexmark x5650
  • 4,041 Answers
Hello there
ok try this my help you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Lexmark 5660 paperjam
printer says paper jam no paper in printer i have on pluged it to clear it and its continueing to say paper jam what should i do?
Oct 20, 2012 | Lexmark X5650 All-in-One InkJet Printer
Paper jams reacurring
dear dragonsfure .
you have to follow following steps to reduce paper jams on your printer.
step 1: turn off your printer.
step 2: remove the paper plates .
step 3: remove the toner or ink cartridge.
step 4: take out jammed paper.
step 4: clear printer with clothes carefully.
step 5:close it step by step.
Feb 08, 2011 | Lexmark X5650 All-in-One InkJet Printer
I need instructions on how to use my Lexmark X5650 scanner
Please refer to the Lexmark X5650 User's Guide. If the printer's software is already installed on your computer and you're using Windows, you can view the user's guide by going to the Start menu -> Programs -> Lexmark X5600 Series -> User's Guide. If not, you can download it for free using this link Lexmark X5650 User's Guide.
Thanks
Dec 12, 2010 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5650 All-In-One InkJet Printer has a carrier paper jam how do i fix it
Hi. Here's an article in the Lexmark website that might help you out with the carrier paper jam problem. Just go to this link http://bit.ly/btHg8D. If you have tried all of the troubleshooting steps found in the article but still getting the same problem, you might be having a printer mechanical problem. If that's the case, I suggest you call Lexmark at 1-800-LEXMARK(1-800-539-6275) for assistance. Make sure to take note of the serial number found behind the printer.
Apr 25, 2010 | Lexmark X6575 All-In-One InkJet Printer
I havw a lexmark x5650, how do i get the fax to print out of the memory
my printer lexmark x5650 says the carrier is jammed how do i fix it
Mar 19, 2010 | Lexmark X5650 All-in-One InkJet Printer
My lexmark x5630 has been showing paper jam but there is nothing inside the printer thats stoping it please help.
Hello. Try removing all sheets of paper from the printer. Make sure to check in the feeder by peeking inside it. Clear any foreign objects. Open the printer cover, and remove the cartridges. Clear any foreign objects around the cartridge carrier. Close the printer cover without the cartridges. Unplug the printer from the power outlet. Plug the power back after 10-15 seconds. It should power on automatically. When printer asks for the cartridges, load them back in. Close the cover down. Printer will print an alignment page. Just let it finish print the page. When there's no more error, try to make a copy or print from the computer to check. Hope this helps.
Mar 09, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
X5650 Unrecoverable scan error. Does not feed the paper.
that sounds more like a mechanical issue. You might want to call Lexmark at 1-800-LEXMARK about the problem. Hope your printer is still within warranty. Hope this helps.
Jan 27, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
My Lexmark X5650 all in one printer displays a paper jam error but there is no paper jam. And I can't seem to get it to disappear after turning it on and off and unplugging it.
Inspect entire paper path for even a little shred of paper. All it takes to block a sensor, or hold down a "finger". if nothing at all, could be one of the sensors are faulty or unplugged.
Sep 21, 2009 | Lexmark X5650 All-in-One InkJet Printer
I have a lexmark x5650 and evertime I try to print something the paper will feed through on one side and not the other so it doesnt print properly. also it says paper jam. any ways to fix this??
if you have a paper jam error and you don't see a Jam it means the printer just needs to be reset.
Please try this to do a partial reset. Leave the printer on and then unplug it and leave it unplugged for about 1 minute and then plug it back in and turn it back on and see if the problem persists.
About the paper feed, first check the printer preferences, go to start, select printer and faxes. Mark the Lexmark printer, click right mousebutton and select properties from the menu list.
Check that you have set paper size to DIN/A4 and adjust your other settings as needed.
If the problem persist check if you have the latest drivers installed, if this doesn't help I think you will need to contact lexmark support.
Aug 26, 2009 | Lexmark X5650 All-in-One InkJet Printer
I have a paper jam in my lexmark x5650
hi try firstly to open the paper mount and then put ur hand to see if there is a paper jam there if not, try to open the color cartridge mount and remove the colour cartridge and install it back again if not, try to turn it off and on again.
Jun 07, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5650 All-in-One InkJet Printer Logo
816 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
