Question about Toshiba M685 VHS VCR
Black and white on my tapes
I recorded a show on my vcr and the tape comes out in black and white. It is not the tape because I taped something in a different vcr and it came out in color. Do you know the solution to my problem? If so I would really appreciate it if you gave me some feedback
  • 417 Answers
Is the vcr sitting directly on top of, or underneath the TV? If so, this could be causing magnetic/static interference, and that's not good. It's good practice not to have anything that uses tape near speakers or TV's. Hope this helps.
Another possibility is the signal you are recording is coming from a cable box/digital cable box/satellite cable box. Try recording using the RCA cable inputs and outputs, instead of 75 Ohm cable, if applicable.
Posted on Apr 28, 2010
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
SONY keeps switching to EP at beginning of playing SP tapes
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
Apr 27, 2012 | Sony Televison & Video
Recording instructions
well if the vcr is hooked up and you can watch a show on it put in a tape that has a movie on it then press play if you can see the show take out that tape put in your blank tape find the show on your tv u wish to record press record try this before the show comes on record a little bit of a show like 30 sec or so then rewind and play back to see if it did record if it did just repete this when the show that you want to record comes on hope this is helpfull....
May 30, 2010 | Panasonic AG-DV2000 Mini DV VCR
What are the steps to dubbing off the other tape?
You need a set of RCA AV dubbing cables (available at fine electronics stores everywhere), and a couple VCRs. Plug the cables into the "A/V Out" jacks on the back of the VCR that will be playing, and into the "A/V In" jacks on the VCR that will record.
Also on the recording VCR, use a regular coaxial cable to attach it to a television.
Now, set the TV to 3, fire up the VCR's, and set the recording VCR's TV/VCR toggle to VCR. Also on the one that is recording, set the channel to "INPUT" or "AUX" or something like that. (You're telling it to record what it sees coming from the jacks you plugged the cables into.) Then hit Play on the other machine. You should be able to see your tape playing back. If you do, you have followed these directions correctly, and you're ready to make your dub.
HINT: The first few feet of tape are often prone to dropout and generally sucking. Record a minute of black before making your dub. Mark this on the tape or tell them when you turn it in. They will be impressed.
May 28, 2010 | Sony DTC-ZE700 Dual Cassette Deck
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
My tv shows are taping in black and white
if you have the dvd's s-video plugged in and also something plugged into the yellow video input this will happen , does the piture on the tv show black and white?
otherwise the vcr head is dirty and needs to be cleaned
please rate a fixya and I'll be happy to even assist you further
electech
Nov 07, 2008 | Samsung DVD-V2000 DVD Player/VCR
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Toshiba M685 VHS VCR Logo
122 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
