Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Washer, not spinning. Belt looks ok, front filter removed and cleaned. Previous answers say motor brushes, how are these looked at? Access through the back, would prefer not to take dryer off to access top, but will if only way to get to brushes. It looks like motor is on bottom.
  • 1 more comment
  • tony409 Apr 25, 2010
    Ok, how does motor come out the back?
    Motor disconnected, how do the brushes come out?
  • tony409 Apr 26, 2010
    This link has very good helphttp://www.fixya.com/support/t3041295-wa... I softly knocked the brushes and sprayed the commutator with electronic cleaner and wiped it down, the spin cycle is working again, though probably only temporarily. It should get me through until I can get a new set of brushes.
    Scholar:
  • 126 Answers
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
Posted on Apr 25, 2010
  • BRIAN
    BRIAN Apr 25, 2010
    THIS BOLTS TO THE TUB WITH 10MM HEX HEAD BOLT. I BELIEVE.THE ARE 2 OF THEM ON THE BACK SIDE. UN BOLT AND PULL MOTOR BACK.
    DO YOU HAVE A METER TO TEST THE MOTOR?
    TEST FOR CONTINUITY THESE NUMBERS ARE ON THE PLASTIC MOTOR CONECTOR AND SHOULD BE MEASURED WITH THESE VALUES. IF ONE IS OUT OF RANGE MOTOR IS BAD. ARE YOU SURE YOU DID NOT HAVE THE MACHINE SELECTED FOR NO SPIN BEFORE YOU START.
    2-3 0.8-2.0 OHMS
    4-5 2-10 OHMS
    6-7 14-240 OHMS
    IF THERE IS NO REAR PANAL THEN IT HAS TO BE TILTED BACK. BUT I AM SURE YOU HAVE A REAR PANEL.
  • BRIAN
    BRIAN Apr 25, 2010
    I NEVER TRIED TO REMOVE THE BRUSHES SO I DO NOT KNOW THAT THEY CAN BE.
My whirpool washer does not spin in rinse cycle
pull out the plug first ???
have you cleaned the filter ,this is the first thing to do
next check the motor brushes
May 27, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Washer drum not spinning - how easy is it to replace the nedded part? I assume it is a belt
Sounds more like motor brushes,,,Some are sold as half motor, you can check this model on Espares.co.uk, parts cost vary from £ 15.........£65Half motor..Good luck
Feb 27, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washing machine
You should find the filter located behind a removable plastic panel at the bottom front of washer. Unscrew it anti clockwise to remove and clean it out.
Pl rate me 'very helpful' for the free help, thanks!
Jun 05, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Spin cycle does not work, belt is attached. Everything else works fine, is there a reset button for the motor? Problem started after washing two small couch pillows.
Possibly a blocked filter, or worn brushes in the motor.
The filter should be located at the bottom right front of washer, behind a drop down cover.
Unscrew anti-clockwise to remove and clean..
If no improvement, then you are going to have to check the brushes in the motor.
Replace if they are less than 2 or 3 mm long.
Hope this helps.
Dec 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Doesnt spin on spincylce and just makes a rattling noisewff1475 bosch
The rattling noise is probably something in the pump.
If it is not draining properly, this will stop it spinning.
Check pump filter, if clean, then I would suggest you check the brushes in the motor for wear, as badly worn brushes will also stop it spinning.
Please rate my solution.
Thanks.
Nov 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Won't spin
The most obvious thing that comes to mind is that the brushes need replacing in the motor
You will have remove the motor to check them.
The brushes are located at the rear end of the motor, you will see the wires going to them
Plz rate this solution.
Thanks.
Dec 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Won't spin - belt fine!
I had the same problem with my Bosch 2060, which is almost 6yrs old. After opening the back of the washer and inspecting, belt looked good and not loose. Spending several hrs on net looking for postings, most thinking replacement of motor brushes is the solution. Someone posted that the connector on the right side of motor (located under the tub) to the right side could be loose. I pushed on the connector to make sure it was tight. Powered up and went to spin cycle and was greatly relieved that washer began to spin. Thanks for whoever posted this simple fix.
Jan 07, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2060 front load
bad belt bad motor bad motor control unit bad ccu or wires un plugged if you can hear the motor rum check belt one time i had a nail jamming the tub through the holes in it like to never found it in that stainless steel tub lol
Dec 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Wont spin, and arcs.
2 bruhes in motor
replace motor brushes
use correct brushes from bosch
Oct 09, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
468 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
