Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Washer does not drain but recognizes all other functions
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
Washer not draining
Too short description. Washer show same code? Maybe you turn wrong program without draining function? Same program for wool or synthetic not draining 100% it can left water.
Oct 13, 2016 | Washing Machines
What does half 6 E error code mean on LG washer
make sure the drain hose is higher than the back of the washer, has to be to function the draining of the unit.
Jan 02, 2015 | LG Washing Machines
Washer drains as it fills
open the back of the washing machine check if the drain valve is functioning properly
Jun 29, 2012 | Maytag PAV2300 Top Load Washer
Washer drains then the "no
Your machine has control switch problem,it will need servicing.And will need replacement.The switch is the problem(function selector).It has connectors an wires(color coded)for a required function and if the function is different from what was indicated in the switch then the problem is the internal part of the switch which sets the wrong function and as for self protection from further damage the unit set its self off.
Jan 31, 2011 | Washing Machines
The clothes smell after washed...the drain is not plugged by a coin or other obstruction...however the drain hose has a slime film starting from the pump to the wall drain...the check valve after the pump...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Aug 31, 2010 | Maytag MAH8700A Front Load Washer
The washer didn't spin or drain out. So, I turned
The washer has a separate pump to drain. You manually drain out that means the pump is good. The agitation and spin rotations are from one motor and this motor has 2 directions with 2 mechanisms to assist the actions when the motor connections is controlled by the set table. When the parts contributed to the mechanism fails you can have only one function or neither of them. To examine the mechanical failure, need to access to the inside to inspect the clutch, the brake, the helix... This needs a service man or if you can do it if you are handy. To confirm the problem, here are things to check without taking the washer apart.
1- If you have agitation, but no spinning, then your motor is good, just the spinning mechanism is failing. Need to replace a small part of the mechanism after inspection. In this case, you can't even run a manual spinning. 2- If you don't have agitation then you may have the motor problem. 3- If you hear motor sound but no turning, then need to inspect the belt or direct drive mechanism. The spinning mechanism part is not expensive but the labor is not since there is a lot of work to get to this point. Just to give you the idea to avoid the recognize a rip-off. There is a plastic pulley when engaged with a reversed rotation will push the brake open so a spinning action can function. When this plastic is worn out, it can't engage therefore no spinning.
Jan 02, 2010 | Washing Machines
Washer leaked out front now will not perform any function/ drain
THIS WASHER ISN'T DESIGNED TO WASH SUCH ITEMS, YOU NEED TO REPLACE DOOR LATCH AN MMC
May 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Maytag Washer not working...
bushes on electric motor worn need new ones this will cut supply to washer
Jan 11, 2009 | Washing Machines
The tub never starts to spin when it hits spin cycle.
If your washer functions when the door is shut it cannot be a door problem. The likely thing here is you may have a drain problem....your drain oulet filter (or out pump) could be blocked. This requires cleaning; when the washer goes thru all the functions except spin it is most likely your drain is clogged. Aft u have cleaned the filter & pump check by a small spin. Before you attempt, wall socket off & keep bucket handy to collect water.
Apr 29, 2007 | Crosley CW6000 Front Load Washer
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
82 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
