Question about Mtd 22" Yard Machine Push Mower
I have a MTD zero turn mower when turn on the mower deck the motor will start to cut out.If I turn the deck back off the motor will run fine.
  • 143 Answers
Sounds like a faulty grassbox switch.
Posted on Apr 25, 2010
I need a diagram to mount cutting belt for Craftsman Lt100 - 21 Hp Model 917.27352
There should be a diagram on the mower deck,or sometimes under the foot rest of the mower,otherwise it's off to Sears web site for a manual !
Apr 20, 2013 | Mtd Gold 42" Zero-Turn Mower -
I have a mtd yard man 22inch / mulcher . My question is how do I get the mower to start mulching ?
For mowers like yours, there are straight cut discharge blades (for bagging the grass) and there are more expensive upswept mulching blades. Any holes in the sides of the deck must be covered to mulch as the blade keeps the grass up in the air under the deck, repeatedly cutting it...over and over..till it falls on the ground.So use a solid deck with the upswept type blade.
Aug 31, 2010 | Mtd 22" Yard Machine Push Mower
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
My zero turn mower's deck was knocked off. I put
if it got knocked off, i'd guess it hit something pretty darn hard. i'd check first for bent blade[s], then bent or broken mandrels
Aug 23, 2009 | Garden
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Mtd 22" Yard Machine Push Mower Logo
109 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
