Question about Maytag Atlantis MAV6000 Top Load Washer
I have a dart stuck under the agitator. How do I remove the agitator to get it out?
    Scholar:
  • 126 Answers
Pull the top cap off down insde the agitator is a bolt. it is a 1/2 inch or 7/16 inch in size. remove the bolt and lift up agitator.
Posted on Apr 26, 2010
I got the strap of my swimsuit stuck under the agitator of my Hotpoint washing machine. I removed the top layer of the agitator, but don't know how to get under the part beneath it.
With the first part of the agitator off you now have to remove another cap off the top of what you now see. Under that will be a bolt that holds the whole bottom of the agitator on.
Feb 28, 2015 | Hotpoint Washing Machines
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
I have a sheet stuck under the agitator of my GE gtwn3000mws. I've tried to use leverage to brute force the agitator out and it was a no go. Then I took off the top cup looking for the bolt to r
Remove the fabric softener cup, remove the plastic insert, then there is a 7/16th bolt you need to remove and the agitator will lift out.
Here is a diagram of the tub assembly.
Regards,
Richard Roth
http://appliancecafe.com
Nov 13, 2012 | GE GTWN3000MWS Washer
Towel stuck under the agitator..cannot be pulled out, agitator turns clockwise, agititor gets stuck turning counter clockwise
You will probably have to remove the agitator, There is a bolt on the top, take this off and lift off the agitator
sudinw8a1y.gifitator
Sep 22, 2011 | GE WPRB9250C Top Load Washer
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
May 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Remove the agitator
The agitator is actually pressed on without mechanical fasteners . Grab the bottom of the agitator firmly on each side. Pull up with a quick, hard **** (careful not to hit your face). If this does not work, wrap a belt under the agitator. Grab the belt firmly and pull up with a quick, hard ****.
Dec 25, 2008 | GE WBSR3140DW Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
