PHASER 7750 WITH THIN WHITE LINE DOWN MIDDLE OF LONG EDGE OF PAGE. I have a thin (about width of a human hair) running down entire long edge of every printed page that has magenta in the print. I ran the solid fill test pages and the line only shows on the magenta. I replaced the magenta imaging unit and the line is still there. I have also changed the transfer roller and belt cleaner. I have heard that this problem can only be the imaging unit or the developer. Can someone confirm that please? Also, assuming the problem is the magenta developer, can i have the part # for the magenta developer and instructions on how to change the magenta developer? Thank you in advance. - Scott
  • info15108 Apr 25, 2010
    Perfect. thank you very much.
    Genius:
  • 1,043 Answers
Go to the following website:
http://www.eserviceinfo.com/download.php?fileid=43818
This will take you to a page that will allow you to download the complete service manual for free. Just click on each number in turn to the left of the Multipart heading. Inside you will see the printing troubleshooting guide as well as a complete parts list. This should give you the information that you need to be able to resolve your printer issue.
Posted on Apr 25, 2010
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
From the middle down to the bottom of my phone dosen't work. Have to keep flipping sideways to do anything
Let's start with the basics, and no cost fix, as sometimes the culprit is a tiny amount of gunk/debris at the very edge of the screen that gets embedded between the screen and the small groove around the screen.
Take like a toothpick or very thin pointed-edged piece of plastic and scrape out any gunk/debris around the entire edge of the screen. A lot of times greasy gunk gets in there and prevents the screen (digitizer) from working in certain affected areas.
Try that and post back with the results to see if that helped.
Nov 01, 2014 | MetroPCS LG Optimus F3 4G
When using the automatic document feeder to print,scan, or fax, the finished page displays a thin line about 5-3/8" inches from the left edge of a 8.5x11 paper. When using the flatbed, no line is...
You need to change the mylar strip on the ADF and also you need to clean the narrow strip of glass that the scanner uses for ADF scans. The Mylar strip is found by opening the lid, as you do when you put a document on the glass. On the left side you will see a Mylar sheet that covers a white backing section. There is a latch on the front and back of the Mylar mount that allows it to drop down. There should be spare Mylars in an envelope tucked under right edge of the white backing strip for documents placed on the glass. Just be sure to orient the new strip the same as the old one. The mylar strips can sometimes be cleaned but usually it is better to replace it if you have spares.
Aug 09, 2011 | HP LaserJet 4345mfp Printer
How do i remove a white streak that runs down the
there should be a black thin wire with a button to move over that wire that cleans it. I would also take out the toner and make sure there is no stains there
May 04, 2010 | OKI C5200n Laser Printer
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
White stripe in print-outs
This is a common problem with this printer. Each toner color has it's own roller. The tin blade on the inside edge of the roler gets plasticy buildup and needs to be cleaned.
Pull out the entire toner roller assembly for the color that is problmatic. Unscrew the tin blade from the roller assembly. Clean the inside edge of this blade (the part that scrapes on the roller) completely. NOTE: After cleaning mine with toilet paper & water I ran my fingernail along the edge to find that the waxy buildup was still there. I gently took my fingernail and scraped at it until it felt smooth -- no burrs.
NOTE: The edge of this blade is very sharp! Be careful. Don't run your finger along the edge.
Reinsall the tin plate maing sure that the foam sweeps (on the right and left of the blade) are not stuck under the tin blade. (If you do, it will dump large amounts of toner on your pages. Very messy).
Give her a whirl.
Apr 05, 2009 | Samsung CLP 300 Laser Printer
Laserjet 5p leaves a thin white vertical line when printing
Either the drum and/or developer is scratched or has a line on it ..
Dec 26, 2008 | HP LaserJet 5p Printer
Dirty printing job
Are they lines from one edge to the other in a straight line. Or is it faint reprint across the page?
Thin lines would most likely be a bad drum or cleaning blade.
If it is faint reprint it is the heat roller in the fuser.
May 22, 2008 | Xerox Office Equipment & Supplies
Samsung SCX-4521F All-In-One
If the lines only appear when using the top feeder, then theres probably white-out or something on the thin strip (called a slit glass) of glass on the left of the large glass.
If it appears when you put a document on the large glass, then it is another problem.
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
jasbo
jasbo
