Question about GE Nautilus 24" Built-in Dishwasher
I have ge nautilus...it has been working great but last time i turned it on it worked for app 3 mins then just got quiet. its not making any noise. wondering if anybody has suggestions as to what might be problem. i checked the breaker..it wasn't tripped. any ideas would be helpful. thanks
    Problem Solver:
  • 11 Answers
Sometimes the door switches go bad. If you are handy you can break it apart and clean the contacts.
Posted on Apr 28, 2010
How to fix my Facebook app on Android tablet. No longer looks or preforms like the normal app. Think malware is involved.
A few suggestions:
1. Ensure you are using a good (fast) wifi connection.
2. Make sure there are not too many apps running in the background on the tab at the same time (using resoures). Close unused/unneeded ones.
3. Check for updates to your tab's system software. If available install the latest update.
4. Log into Facebook with a browser app instead (i.e. chrome, firefox, etc.). Check if there is a problem after 30 min. or so accessing Facebook this way.
5. A full system reset will probably fix the problem (unless there is also a hardware component problem with the tab). But it is a lot of work to reinstall apps, accounts, etc. (... consider only as a last resort).
Aug 25, 2015 | Tablets & eReaders
Recently glasses started to finish foggy and
MOST OF THE TIME "FOGGY GLASS" IS A RESULT OF SOAP BUILD UO IN THE DISHWASHER. IF YOU HAVE A WATER SOFTENER AND FILL THE SOAP CUP ALL THE WAY THEN THIS IS THE CASE. FILL A COFFEE CUP WITH WHITE VINEGAR AND PLACE IT ON THE UPPER RACK, RUN AN EMPTY LOAD ON HEAVY DUTY WASH, THIS WILL STOP THE PROBLEM, YOU MIGHT NEED TO REPEAT IT 2-3 TIMES BUT IT WILL WORK, AFTER THAT JUST USE AS LITTLE SOAP AS YOU CAN, IN MY GE I USE POWDERED CASCADE BUT ONLY FILL THE SOAP CUO TO THE BOTTOM LINE, WORKS GREAT. GOOD LUCK
Jun 10, 2010 | GE Nautilus 24" Built-in Dishwasher
Water Dispenser Making Noise
Usually this means you forgot to turn the water on, once water is in the valve it should quiet down
Dec 19, 2017 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Problem draining became problem with filling
Hi I would look at the water valve. Located left front . Remove the front panel , the bottom panel. check the water valve
Dec 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Nautilius not running
drain motor doesn't work, yo cn hear a little noise but maybe to hot, th motor doesn't turn.
Jun 29, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
123 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
