Question about Sierra '03 - '06 1500ld/hd and 2500ld Black Grille Guard
Put a starter in a 87 chev pickup just spins
Put a starter in a 87 sierra pickup and it just spins and dosent touch the fly wheel do ineed shims
How are the teeth on the flywheel
Posted on Apr 25, 2010
My truck starter stays on after a start the truck
starter relay may be stuck solenoid sticking if starter has been replaced may need to shim starter some reman. starters the gear spacing is too tight beteen starter and fly wheel
Mar 23, 2013 | 1999 Chevrolet S-10 Pickup
Have a 95 chev s10 with 2.2 and standard trans. intermiten won't start when it dosen't start I can hear the starter spining but it dosent engage with the motor,already replaced starter and selenoid and...
Was the starter shimmied to match up with the fly wheel properly so the starter gear fly wheel ring gear don't bind or out to far apart that they don't reach each other. The other problem is that if the starter gear was to far apart, it may have shaved the teeth on the starter gear causing your engine not to turn.
Feb 25, 2010 | 1995 Chevrolet S-10 CA Edition
Put new starter (twice) on my 1993 Ford Explorer V-6 engine. Car does crank, but has a grinding noise. Please help.
i think you have either a spaceing problem ie need to shim starter or your fly wheel is damaged look at teeth on fly wheel make sure there good also check your book and see if there are shims on that starter
Jan 30, 2010 | Ford Explorer Cars & Trucks
I have an 87 camaro. In the morning when i try to start it up, the starter spins freely making a "whirrrr" sound. After about a dozen turns of the key, it finally does start, and it starts everytime after...
There is a "bendex drive" in your starter and it pushes the gear into the flywheel when the starter turns. It needs to be replaced because it obviously isn't working properly. The starter basically has to come apart to do this so you may be just as far ahead to replace the starter. Hope this helps.
Oct 22, 2009 | 1987 Chevrolet Camaro
Grinding
It could be the flywheel, but try putting different size shims in between the starter and engine.The starter might be a little to tight against the flywheel. You should be able to get the starter shims at any auto parts store, or ask where you can get some.
Mar 12, 2009 | 1987 Jeep Wrangler
Replacing starter on 1996 s10
if it is an after market starter, make sure it is manufactured in the usa or it will not alighn correct, you may have a fly wheel wear, shimming will only cause it to wear more (estimaternotfree@yahoo.com)
Mar 01, 2009 | 1996 Chevrolet S-10 Pickup
Starter turning engaging not start
 you need a shim, if its screaming your clearance is to great. Are you positive its the right starter?
Feb 19, 2009 | 2003 Ford Ranger Regular Cab
Starter Problem
if you drop the trans. dust cover on the bottom of the bell housing you should dee your fly wheel. Place your starter in the position and line up the shims (if needed) . adjust the starter in enough to where it clears the torque converter and shim outward if needed
Feb 02, 2009 | 1998 GMC Sierra
Sierra '03 - '06  1500ld/hd and 2500ld Black Grille Guard Logo
Top Sierra Boating Experts
Jeffrey Turcotte
Jeffrey Turcotte
Rick Offinger
Rick Offinger
perry richard
perry richard
Are you a Sierra Boating Expert? Answer questions, earn points and help others
