Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
asd-76
Sounds like you turned the machine off whilst hdd was working and corrupted some sectors. Replace the hdd. It slots out and is easily upgradeable. It even tells you how to in the manual.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their untill you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
