Question about Roper RES7646KQ Electric Dryer
Roper dryer idler pulley has fell of where does it goes
  • usera1365 Jun 10, 2008
    Whice set of slots do it go in. There are four slots there or two sets, Whice one do we put the pulley in?
  • detcej Dec 15, 2008
    Dryer will not spin with clothing in it. I replace the belt and how do I put back the tension pulley
    President:
  • Roper Master
  • 2,651 Answers
It hooks in the back 2 set of slots just under the motor assy, with the U- turn portion of the bracket facing to the right, so the belt will be fed through under the roller, and by applying pressure (pushing the roller to the right loop the belt around the motor shaft, and release. tension should now be applied to the belt assy and the idler will be locked in place
Posted on Mar 24, 2008
I need to know where the idler pulleys go on the motor
Dryer Repair- Replacing Idler Pulley Wheel (Whirlpool Part ...
? 13:58
www.youtube.com/watch?v=WX0KjiQJWpY
Apr 7, 2011 - Uploaded by PartSelect Dryer Repair- Replacing Idler Pulley Wheel (Whirlpool Part# 6-3700340) ... Kenmore, KitchenAid, Roper, Maytag, Crosley, Jenn-Air, Hardwick, ...
Sep 15, 2015 | Dryers
There was a pulley at least thats what it looks like laying on the bottom of my dryer how do I fix it to make my dryer spin
hello berna.... that pulley is the idler pulley which keeps tension on the belt which turns the dryer drum. It apparently came unattached or in some cases unbolted. It will have to be put back in position. The dryer belt may also be broken or worn. consiter replacing both the belt and the idler pulley. Joe
Jul 02, 2011 | Roper Dryers
I'm trying to figure out where part #3346 goes on a roper REX5634. Pretty simple right? But I can't find it anywhere and no where looks obvious. help! Pleeez
if your part number is correct it would be the idler pulley tensioner for the drum belt and installs right next to the dryer motor inside the units lower area to keep belt tension on the drum belt
Feb 02, 2010 | Roper REX5635E Dryer
A constant clicking noise near the motor of my maytag dryer. seems something is slipping as occasionally the drum and belt slow down
It sounds as if the idler bearing has started to fail see this picture http://sites.google.com/site/sublimeappliancerepair/_/rsrc/1246721031553/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info/Norge%20dryer%20with%20drum%20removed.jpg
The idler pulley in the picture is behind the motor.
I would check the ilder pulley to see if it rotates freely and does not have any odd side to side movements. If it does then replace the idler pulley and belt.
Belt: http://www.appliancepartspros.com/part_details.aspx?part_id=4043963&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d47809%26diagram_id%3d681078
NOTE: Before you remove the idler pulley and belt note carefully the installation position of the belt, idler arm, spring and the idler pulley. For a first timer trying to do this it can be quite frustrating to get them all positioned correctly.
Idler pulley:
http://www.appliancepartspros.com/part_details.aspx?part_id=4373393&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d49146%26diagram_id%3d673577
I hope this has been useful information to you. Good day.
Jan 06, 2010 | Washing Machines
The belt fell off of the drum, i have the front off but i dont know where the disconnected pulley goes.
Unplug dryer or disconnect power.
Locate mounting slots in front of motor. (In some cabinets, there are two sets of slots for mounting the idler assembly. In this case, mount the idler assembly in the slots that line up under the grooves in the motor pulley.)
Install idler assembly into cabinet base by hooking mounting tab (A) into 1⁄4" wide mounting slots and setting mounting tabs (B) into the 3⁄16" wide mounting slot.
Make sure belt is around drum, with grooves down.
Route belt through the idler and around the motor pulley.
Sep 12, 2009 | Whirlpool Dryers
Idler pulley came loose and I need schematic so I can put it tog
the idler pulley fell out of its slot or it broke into pieces
if it just fell out of the slot you should take out the drum and just kind of play with it  depending on the dryer if you gave me your model i can take a look  and i dont know what kind of idler pulley you have so i am not much help AT ALL without it i;m sorry
Jun 08, 2009 | Kenmore 62622 Electric Dryer
Putting the belt back on a roper ras6233kq1?
HI thanks for your question. so I assume you have the dryer apart, and just don't know how to install on the pulley. . after the belt is on the drum and the belt is hanging.. double the belt and push under the idler pull y , and then on to the motor pulley. thanks . please rate my answer. thanks the appliance doc.
Oct 11, 2008 | Roper RAS6233KQ Top Load Washer
Roper electric dryer
this should help couldnt find an actual picture so i took the time to draw a simple on in paint for you
Sep 27, 2007 | Roper REX4634KQ Electric Dryer
Roper RES7646KQ Electric Dryer Logo
73 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
