I have a samsung lnt3253, and the fault I am have it that I have audio, but no picture. Pressing Menu doesn't display anything. Any Ideas?
Check caps in power supply
Posted on Apr 26, 2010
Changed battery now radio doesn't display song or artists name. How do I fix this?
Once you disconnect the battery everything that is in your memories goes "poof" it will take a little time for all of your stations to come back. If I'm not mistaken you still have to set those manually. Radio is mostly satellite that's why you get song names etc. So drive let the computers collect data and before to long you'll get to see this names come up again. Hope this helps.
May 04, 2015 | 2010 Ford Edge
I have a 2006 ford fusion which the radio system
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna
  • Antenna cable
  • Door trim panel(s)
  • Speaker(s)
  • Noise suppression equipment
  • Smart junction box (SJB) fuse(s):
    • 12 (7.5A) (accessory delay feed)
    • 17 (20A) (subwoofer amplifier) (Audiophile)
    • 18 (20A) (audio unit hot at all times)
    • 22 (7.5A) (audio unit hot in START)
  • Battery junction box (BJB) fuse(s):
    • 20 (20A) (LH audio amplifier) (THX®)
    • 21 (20A) (RH audio amplifier) (THX®)
  • Circuitry
  • Digital signal processing (DSP) module (THX®)
  • Subwoofer amplifier (Audiophile)
  • Audio amplifier(s) (THX®)
  • Audio unit
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • CAN circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for the audio unit, Go To Pinpoint Test A .
    • NOTE: Do not press any buttons on the audio unit while the audio unit is carrying out the self-test. System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out self-test diagnostics for the audio unit.
  1. If the DTCs retrieved are related to the concern, go to Audio Unit Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, and the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
NOTE: To enter the audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the key OFF or the audio unit off.
  1. If the concern remains and the fault is not detected, GO to Symptom Chart to continue diagnostics.
  1. The self-diagnostic mode has the following functions available:
    • Preset button 1 = On-Demand Self-Test. This button runs the on-demand self-test.
      • Pressing the MENU DOWN button allows scrolling of any DTCs found during the test while in this menu.
    • Preset button 2 = Display Continuous DTCs. This button enables viewing of any continuous DTCs that have been logged.
      • Pressing the MENU UP button allows scrolling of any DTCs while in this menu.
      • While continuous DTCs are being displayed, pressing the EJECT button will clear all present DTCs.
    • Preset button 3 = Signal Strength Test. This button displays the signal strength.
    • Preset button 4 = Software Version Display. This button displays the audio unit software version.
      • Pressing the MENU UP button allows scrolling of all audio subsystem software versions while in this menu.
    • Preset button 5 = Display Test. This test illuminates all the display segments for 5 seconds, then turns all segments off.
    • Preset button 6 = Configuration Status. This button enables audio unit configuration status.
      • Pressing the MENU button displays the ACM part number while in this menu.
  1. To exit the self-diagnostic mode, turn the audio unit off or turn the key OFF.
Feb 05, 2018 | Cars & Trucks
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
I rebooted my PC and now screen is darker and my colors are off
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Oct 18, 2009 | Samsung Yepp YP-T9 Digital Media Player
When I turn my camera on, the lcd doesn't display. I can review an image though in the play mode. any ideas??
Rebel XT doesn’t have live view function. You cannot have picture on LCD when taking picture. If you can review the pictures and operate menu on LCD, your camera just fine.
Aug 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Fault on my Transceiver
You posted your concern as generic with no specific brand or model. Flashing displays can mean a variety of things to different makes. Some of which are:
1. Low battery. Low memory battery;
2. Error in programming;
3. Error in firmware;
4. Fatal error in self-test/diagnosis;
5. Major component defect detected; and/or
6. Out of range/band.
In the same token, corrective measures can likewise be anything:
a. Recharge/replace battery;
b. Reprogram/reload program;
c. Update firmware/clone;
d. Run diagnostics using an external device (often a PC);
e. Determine which is at fault (finals, VCO, PLL, voltage regulator, replace);
f. Tune back to standard freq.
Most often (but not always), it can be also be corrected by doing a reset of the radio which can be:
i. Pressing FUNC (or some other button) while powering up;
ii. Pressing a recessed/hidden reset button;
iii. Placing a temporary jumper/shorting two (2) points (internally on the logic board);
iv. Remove battery/power (including internal if any);
v. Pressing a sequence of buttons to enter MENU/SETUP mode.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information. Would appreciate also if you can specify brand/model/region.
Good luck and kind regards.
Jan 18, 2008 | Radio Communications
LCD TV
I had a problem with a Samsung 46 inch LCD and it had audio and dim light but no picture and found out that the logic board toward the top (inside tv) was bad and was no longer available and the only way to fix it was to get the entire display panel (the logic board came with it) It was not costwise to repair. Hope this helps.
Dec 28, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
