Question about Intel Motherboard
Display on laptop
In early Dec a constantly running vertical broken line appeared on my display beginning near last digit of the clock display. About 2 mos later another line appeared to the right of that one (very edge of display and as of yeaterday another appeared about two centimeters to the left of the first line. Please tell me what is causing this. No one ie Intel or HP can seem to tell me what the problem is or how to fix it. Can you help? I have updated bios and uninstalled and reinstalled the graphics driver to no avail.
  • barbswad Mar 24, 2008
    I don't have an external moniter to try this on but I will find one ASAP. Thank you so much for your suggestion.
  • barbswad Mar 26, 2008
    Today I connected laptop to external display and, as you suggested, no lines. Thanks, am now on my way to repairing this problem.
    Genius:
  • 1,027 Answers
Have you tried plugging in an external monitor to see if the display is ok. I suspect you will find external display is perfect and only the LCD on the laptop is affected.
I have a laptop that the "tab" welds are not connecting properly on the lcd and 1/3 of the display is multiple lines or black. Pressing on the top of the lcd changes the colors on the display but does not fix the problem, I had to replace the lcd.
Posted on Mar 24, 2008
SOURCE:
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Vertical lines
It sounds like dead pixels in the LCD display. the only way to get rid of the lines is to replace the Display unit in the laptop. This can be a very expensive repair so I'd check it in with an IT professional first.
Nov 07, 2013 | Sony VAIO VGN-NS135E/S Notebook PC
DELL e5510: suddenly whenever I turn on my laptop it will just flash with lines that looks likes threads of clothes? then after a few seconds the screen is just black and full of colored vertical lines (...
Here is a hardware test you can run to test the video and lcd screen. That came with your laptop
Diagnostics before windows using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
during the test it will BEEP ! it is asking you if colored bars are displayed. if the bars look ok then your screen is fine but if during anytime of this test and you see the distortion you described then its the LCD screen or LCD cable
hope that helps
Sep 07, 2013 | Dell Latitude E5510 Notebook PC
Sony Mavica CD400 orange vertical line appears.
In lesser digital camera chips, this is typically "vertical smear". It is especially apparent if there is a much brighter light source in the image. I.E., a street lamp on a dark street. I have used an early version of the Mavica and experienced this type of situation with that camera, so am assuming that this is typical throughout the Mavica model line. The work-sround is be particular about the lighting situations you shoot with the camera.
Jul 08, 2009 | Sony Mavica MVC-CD400 Digital Camera
Vertical color lines on display screen
Hi!
If the lines appear while looking at the menu, then it's a broken LCD. If the lines appear only while taking pictures - faulty CCD. Contact your local Sony service center, but if they ask too much, you can contact me at [email protected] and I will give you a good price.
I work in Sony service center.
Tom
Jul 06, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Vertical line on my notebook lcd
Be sure that the LCD display drivers are up to date, if so, reboot system, if you see the vertical line on your display during the boot up process you have a hardware failure.
possible failures include:
LCD panel going bad
Inverter board going bad
Broken trace on the LCD connection ribbon from the graphics card to the LCD
Wrong type / speed / size of memory (i had this happen to me)
Graphics card begining to go bad.
Loose connections may also cause this, make sure the LCD's connection ribbon / wires are firmly connected.
May 30, 2009 | Acer Computers & Internet
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
HP Pavillion zd8000 lines on monitor
To date, HP has refused to repair these defective laptops despite being fully aware that the problems do exist. The only real solution that I'm aware of is to write to the BBB (the one in California located near HP's Executive Offices). HP agreed to repair my laptop at no charge after I went this route. To the best of my knowledge, they replaced the display as I no longer have the vertical lines. It appears that they may have also reduced the processor speed as the computer runs much cooler than it ever did before HP made the repair. It's been several months since the repair was made and, so far, no problems whatsoever. Hopefully that will continue.
Mar 09, 2008 | HP Pavilion zd8000 Notebook
Vertical line on LCD screen
hi unfortunately you'll have to replace the lcd display
Aug 09, 2007 | HP Compaq nc6000 Notebook
Intel Motherboard Logo
116 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
