Question about Garden
Craftsman tiller will not shift into forward or reverse, shift lever moves freely by hand. sears mod.917293550. Do you have a free schematic i can download. Thank You
  • 2,926 Answers
My craftsman rototiller shifts really hard
Check the oil in the transmission.
Consider getting a service manual for your tiller.
www.searspartsdirect.com/partsdirect/brands/Craftsman-Parts
Jul 01, 2014 | Craftsman Garden
Why does speed control lever return to neutral when going forward ?
this model uses a series of groves cut into mower body to maintain the transmission gear/direction , it's held into groves by a spring just under the cover , if this is broken a replacement can be gotten from sears (part# 164X39) to replace it , it should take at least five pounds of force to move shift lever out of grove to next gear , if not then your shift spring is loose or broken
Jun 05, 2014 | Craftsman Garden
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
Craftsman lawn tractor will not engage in forward drive why
Check to see if brake lever is stuck on trans, keeping the brakes locked. should not be any squalling noises. Also make sure belt is routed right. and all idlers spin free.
Feb 01, 2018 | Craftsman Garden
Have a sears craftsman 6.0 rear tine tiller.
Hi little,
The 7.0 hp version does the same thing.
I found that it was caused by the transmission not being fully engaged to a particular setting. when it tries to engage the tines in both forward and reverse, the engine stalls immediately.
After taking to neutral and back a few dozen times I got a 'feel' for it. Has happened in over a year.
Try it. It did take patience.
Best regards
Jul 16, 2010 | Craftsman Rear Mount Tiller
Craftsman rear tine tiller will only go forward. The shift lever will not move to either the ''Till'' position or the ''Reverse'' position
Pretty common failure for all brands unfortunately. The transmission will have to opened up to determine the cause and it is not cheap to have done. Sorry
Apr 27, 2010 | Garden
Sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Aug 20, 2009 | Craftsman Garden
I have power to the tines but the wheels are locked
Tines only spin in the T position.with cutch engaged.If thats not it split the case and check to see the shift fork operating properly. Or that chains are not broke. NOTE This is a serious job!!!
May 11, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
