Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Why kenmore 665 leaks under door
No gasket on bottom just sides and top
    President:
  • 949 Answers
This is common if the wrong detergent was used or some regular sudsing soap like hand dish washing soap was accidentally used. Clear the suds if there by adding a small amount of cooking oil to the soapy water then wash for a bit and cancel drain. Repeat if needed.
If this is not the problem look for something blocking the spray arms from turning, if they spray in one spot only they can splash water out the front.
Check the unit for level, if it is tilted forward it could be spilling while washing.
Look for cracks in the spray arms where too much water sprays from one place.
Make sure the middle spray arm has not fallen off. If it continues try moving the rack to the higher or lower position and see if this helps
Posted on Apr 25, 2010
Kenmore dishwasher model 665-16629000 is leaking out the front. Checked the gasket, ok. Checked the door screws, took the door off, no cracks.
Before I took the machine out from under the cabinet, I would take a really strong light and some hand mirrors and try to see it leaking with the front cover off.
There is not a good chance this can be done.
Other than that, I would pull the machine out from the hole and test it where I could look underneath.
Should be either a drain hose of an inlet hose giving you trouble.
God bless your efforts.
Apr 15, 2016 | Kenmore Dishwashers
Kenmore model #16761691 leaking at the bottom of the door. Where is the gasket located? Or is it another problem?
does it leak all the time or did it just start?try running it with nothing in it and see if it leaks,if the dishes were racked wrong the water can get deflected and leak out through the door,also,remove the bottom rack,look at the screws going around the bottom part under the wash arm,if any of those are loose it causes a wave in the dish washer and the water leaks from under the door.if it's leaking from one of the corners the gasket could be bad
Apr 17, 2011 | Kenmore Dishwashers
Leaks under door
IF LEAK IS FROM AROUND SIDES OR TOP OF DOOR, IT COULD BE THE DOOR GASKET, FIRST MAKE SURE THAT THE DOOR IS NOT MAKING CONTACT ON THE SIDES WITH CABINETS, THEN CHECK THAT THE SPRAY ARM ROTATES FREELY INSIDE AND NOT SPRAYING DIRECTLY ON EDGE OF DOOR. THE GASKETS ARE REPLACEABLE. IF LEAK IS COMING FROM BOTTOM OF DOOR THEN THE PIECE IS CALLED A BAFFLE AND IS ALSO REPLACEABLE. MOSTLY THE PROBLEM IS OTHER THAT DOOR GASKET OR BAFFLE. THE DOOR DOES NOT CLOSE COMPLETELY WHEN CONTACTING THE CABINETS.
Mar 10, 2010 | Whirlpool Dishwashers
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
My Kenmore freezer, model #253.9280212 runs but will not cool below 40 degrees. It runs all the time but I do not hear anything cut on and off. The freezer is 10 years old but looks brand new.
The first thing to check is door gasket< bad corners,gap in side,bottom or top. Close door on a dollar bill and try to slide it top to bottom side to side and if it slides fairly easy then seal is not doing good. If you find dirty area clean it off along with the cabinet side as well.If you find the side is leaking then heat gasket with hair dryer and apply vasoline to gasket to help it move freely. If you find tear or hole then replace it.
Apr 22, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Leak under door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
s7657usut
Mar 07, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Oct 19, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Step1
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step
5
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Jun 08, 2006 | Kenmore 15129 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
203 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
