Question about Maytag Neptune FAV6800AW Top Load Washer
The washer dont take water - Maytag Neptune FAV6800AW Top Load Washer
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with that problem...
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Posted on Apr 26, 2010
I dont know how to heat the water on my pressure washer
most pressure washers are not designed to use hot water.
Sep 10, 2017 | Water Garden
Water dont shut off
Sounds like a faulty Solonoid valve more so since it still happens with the machine unplugged. Not too expensive repair new part to buy around 15 pounds.Not sure in dollars.
Jun 11, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Dont pull the water selenoide good fus gud
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Apr 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Ge washer making a noise trying to pump water out its a wslp1100doww model. How do u change the belt on the washer? precise instruction in detail would be great
if the belt is not broken you dont need to change it remove hoses from pump and clean the pump out...shopvac the water out of the machine first so you dont unleash it all over your house...
Apr 16, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Water level dont stop I bougth a new part and still have the same problem the water dont stop.
put the washer on cold,start to fill washer, turn washer off if water still keeps filling you have a bad water valve,do the same test on hot,if both turn off when you push stop then check the water level hose from the water level switch to the tub,if both ends are secure then replace the water level switch-mike
Feb 18, 2010 | Kenmore 22422 Top Load Washer
I dont seem to get enough water to wash
your washer is domestic,it census how much water should be in there,the laundry mats are commercial washers that cost anyware from $10,000 to $20,000 each they are build to handle a lot more
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Slow flow of water in washer
CHECK WHERE THE WATER LINES HOOK UP TO THE WASHER NORMALLY THERE IS A SCREEN INSIDE THE WATER INLET PORTS
Apr 28, 2009 | LG WM2233H Front Load Stacked Washer /...
Maytag Neptune FAV6800AW Top Load Washer Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
