Question about ViewSonic VG2021m LCD Monitor
The speaker is turned on, but I get no sound. I
The speaker is turned on, but I get no sound. I don't know where to adjust volume.
What os ??? is audio drivers installed ??
Posted on Apr 26, 2010
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
The board don't any sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 16, 2011 | Computers & Internet
Speakers are not loud
Hi ,
down on the very right side of your task bar is a icon of a speaker , click on that and it will allow you to adjust the sound level............let me know if this works ,,,,,,,,,,,,,Roy
Jul 21, 2011 | HP Audio Players & Recorders
We are hooking the speakers up to a new computer and we don't have the software
Threre is no software for these speakers. This is the installation guide:
http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf
Make sure you have the proper sound device activated and volume turned up. If after speaker set up, you have no sound, get into your "device manager" and click on the box next to"sound, video and game controllers"(on right) and, righy click on each device that shows in the list. You should see "disable". If you see "enable" click on that and exit. You should have a speaker icon in your taskbar, lower right of screen. Right click on that and then on "open sound mixer" and, adjust your volume.
Jun 14, 2011 | Logitech Z313
My speakers work fine. I don' t know why thay keep turning. i have the internet. How do i keep my speakers on all the the
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 16, 2011 | Audio Players & Recorders
Acertravelmate4000 got it used,don,t know how to turn off mute,turn on or up volume
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
The volume level may be too low. In Windows, look at the volume
control icon on the taskbar.
Fn-? Volume up Increases the sound volume. Fn-? Volume down Decreases the sound volume.
If this helps u let me know
regards
Jan 12, 2010 | Acer Computers & Internet
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
Sound
Click Start, Settings, Control Panel, then double click the "Sounds and Audio Devices" icon. Make sure the Mute box isn't checked and the Volume bar is at least 1/2 way on the Volume tab. Also click the Speaker Volume tab and adjust the sound there as well if needed. You might also want to check the "Place volume icon in the taskbar" icon so you can easily adjust the sound settings next time.
Apr 20, 2009 | Compaq Presario S5100NX (E120866) PC...
Sony VAIO VGN-CR23G Sound
i have sony vaio VGN-CR23G. i formatted this xp sp2now the sound driver is not installed on my machine. no audio output m getting........what to do..??
Sep 20, 2008 | Sony VAIO VGN-N130G/W Notebook
ViewSonic VG2021m LCD Monitor Logo
102 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
