Question about Brother LS2020 Sewing Machine
Bobbin threads When I start to sew the line goes jagged and when I stop there are about 25 threads coming from the backside and I have to untangle all the thread from the bobbin area with tweezers....
  • 980 Answers
That sounds like the needle is in back to front.
Posted on Apr 26, 2010
Remove bobbin case from singer 5532
I used it once and then the thread jammed ,I had to remover the screws from the top plate and remove the bobbin case and untangle the thread. Now I can't get the needle to pick up the bobbin thread
any idea what I did wrong. I got it for Christmas and am very frustrated with it. Thanks
May 15, 2013 | Sewing Machines
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
Need to know how to properly thread , the problem is once we start to sew it moves a little then stops thread tangles on bobbin and breaks from top. we try different ways of threading
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
Mar 08, 2011 | Euro-Pro 473
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
I have a Brother CS-770. My fabric got pulled down into my sewing machine and the thread got tangled and I got an error message E6. I untangled everything, checked my needle to make sure it wasn't bent...
Hi. It's very likely that the needle is inserted wrong. Take the needle out and make sure that the flat shank of the needle is facing away from you (to the rear of the machine).
Try this and let me know if it helps, ok?
Robbie
Aug 10, 2010 | Brother Sewing Machines
Frister Star bobbin/threading problem
First of all make sure you have the needle in the correct way round, when you thread the machine make sure the presser foot is up so the thread goes between the tension discs, top tension about 4 or 5, make sure you can pull the bobbin thread through with slight resistence and the bobbin should turn anti clockwise in the bobbin case as you look at the open part.
Nov 07, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Janome 9000
The heavy "knitting" on the backside of the fabric sounds like a tension issue due to your thread catcher or other. You may want to look at this link:
http://reviews.ebay.com/SEWING-MACHINE-COMMON-TROUBLES-HELPFUL-HINTS_W0QQugidZ10000000007548289
The fuse issue may very well be unrelated, just coincidental.
Aug 19, 2008 | Janome Memory Craft 9000 Computerized...
Threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Nov 07, 2007 | Janome Mini Compact
Brother LS2020 Sewing Machine Logo
53 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
