Question about Cameras
Camera says memory card cannot be used. - Cameras
  • 1 more comment
  • Anonymous Mar 25, 2008
    When my camera is on its saying the card cannot be used how to solve this problem please help me
  • Anonymous Jun 04, 2008
    my camera says " this card cannot be used"
  • kamila_t Apr 20, 2009
    It already happend to me with the second memory card. After insert it into the camera it says..."This memory card cannot be used.Card may be damaged.Insert another card." But in the computer it still reads the pictures on the card. Please help.
    New Friend:
I had the same problem when I tried a new card recently. In my case the problem was how it was formatted. Unfortunately, the Nikon L3 that have does not allow you to reformat it if it does not recognize it. So instead I cleared the partition table of my memory card under linux by doing the following:
dd if=/dev/zero of=/dev/mmcblk0 count=4 bs=512
(WARNING: this will erase all data on the card)
After I did that, I was able to format it properly in the Nikon itself.
Posted on Aug 03, 2010
When I find out why, I'll say.
Fred, Leeds UK.
Posted on Aug 29, 2008
    Problem Solver:
  • 7 Answers
The max size sd card is 256MB.
Posted on Apr 29, 2009
  • Anonymous Apr 29, 2009
    THE MAX SIZE SD CARD FOR THIS CAMERA IS 256MB.
    Dont try a bigger one, it wont work!
    Its becoming hard to find small sd cards.
    Shops only sell 1GB + these days.
    Although you can get a 1GB for £4 it will be more like £12 for a 256MB.
    When the camera was new, a 256MB would have cost £30!
Check and make sure the memory card is in all the way sometimes it looks like it is, but it's ejected a little bit so push it in all the way
Posted on Mar 23, 2008
6ya staff
SOURCE:
C530 Kodak. Inserted new memory card 1.0gb and took several pics.. Tried to review but message appeared "no images to display on memory card". I can only access a limited number on internal memory???
Is the camera able to use a 1gb card? Use the Camera Setup Menu to Format the Memory Card. Use camera Setup menu to tell the camera to use the Memory card instead of the Internal memory.
Aug 19, 2014 | Kodak EASYSHARE C530 5.0MP Digital Camera
I reformat my sd card in the computer to remove all the photos the when im using it in my sony cybershot camera it appears "reinsert memory card" how can i fix the it to use it again in the camera
When you need to delete the photos from the SD memory card, do not use your computer to do it. Use your camera to format the SD memory card.
To fix this problem, insert the SD memory card in your camera then go to the camera's Menu and format the SD memory card.
Nov 03, 2012 | Sony Cyber-shot DSC-W80 Digital Camera
How to format memory card using PC
If you format the memory using the PC then the memory card may not work in your camera. Format the memory card using the camera, go to the camera's menu and scroll through the settings until you come to Format the memory card, then select it and Format the memory card.
Jun 25, 2012 | Canon PowerShot A510 Digital Camera
When i insert my memory card into my brand new CASIO EX-55O/0 camera,a message comes up and says "card error"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (of which your camera was made before SDHC. You can only use 2GB or less cards). Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 16, 2011 | Casio Exilim EX-S500 Digital Camera
I am using the camera for 2 monthes and now its says memory card error. i didnt changed the memory card SDHC what sould i do
Welcome to Fixya. Getting a card error means that:
* memory card is not yet formatted for camera use
* memory card requires cleaning
* using a incompatible memory card
* camera malfunction
Here are some troubleshooting steps that you can do it by yourself. However if the error message still persist, you should contact your Canon service center.
Memory Card not formatted
You have to format the memory card. Some memory card can't be formatted using a PC's, or formatted by another digital camera. I suggest that you have to format the memory card using the camera itself.
Memory Card requires cleaning
Use a dry and soft cloth in cleaning the memory card and the memory acrd slot.
Using a clean pencil eraser can also be useful in cleaning the memory card but you have to be careful, slightly rub the eraser on the memory card.
Incompatible memory card
Please use a compatible memory card
Camera malfunction
In this case you have to contact you service center. It will be a big help if you can check if your camera is still under warranty to get a free service.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 20, 2011 | Canon PowerShot SX210 IS Digital Camera
I keep getting a card error and I have tried 9 dif cards including a new one and still the same thing.
Welcome to FixYa.
All you need to do is:
Camera malfunction
Apr 11, 2011 | Cameras
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
My camera will not read my memory card anymore. It is only using the memory from the camera. How can I get it to read the memory card
Confirm first whether the memory card is still good or bad by using a card reader, put the camera memory card into the card reader then connect it to your system, see whether the system will read your card, if the system doesn't read it, it simply implies that memory card is bad and you need to replace it with a genuine memory card, but if it works it implies that the card slot on the camera is bad. so, your either need to service your camera or you replace the memory card. Thanks
Sep 24, 2009 | HP Photosmart M417 Digital Camera
Camera can't use memory card
Use the computer to format the card, then see if the camera recognizes the card. If the camera recognzes the card, the use the camera to format the card so it can save to the card. A computer format will not work in the camera,but may allow it to be recognized.
Jun 11, 2009 | Samsung NV15 Digital Camera
Samsung S630 Digital Camera, Card Error and Format Error
you have several options:
1. see in the specification details of your camera what memory card is compatible for camera. for S630 it is SDHC/MMC/SD card (Up to 4GB Guaranteed). see if you're using memory card within this capacity and type. If you're using a different memory card type and capacity, try to use memorycard that is compatible with your camera.
2. try to use memory card to other devcie like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
3. try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error meassage, camera needs service.
hope these options solve one of your problems. c",)
Dec 29, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
1,129 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
