Question about Heavy Machinery
DEK 14 HP CHIPPER ENGINE WILL NOT RUN. WAS RUNNING AND THEN JUST LIKE IGNITION TURNED OFF. IT IS NOT IGNITION SWITCH, NOT LOW OIL PRESSURE SWITCH, HAS FUEL AND HAS OIL.
  • 376 Answers
SOURCE: Just bought a 10 hp troy bilt chipper used. When
As LeeatCSEb said, It's your float needle and seat not shutting off the flow of gas when your carb bowl is full. Have your needle and seat replaced. Dwain
Posted on May 18, 2009
  • 47 Answers
SOURCE: 10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Posted on Jun 22, 2009
  • 5 Answers
SOURCE: I have Chipper/Shredder model 47321, 10 HP. I have
If you don't see an inline filter then the only filter is a screen in the fuel tank. Sounds like the engine is not getting the fuel it needs. Check the tank and clean as nessesary the screen maybe plugged. If you leave fuel in the tank for long periods of time with out using a fuel stabilizer your carb may need cleaning. Old untreated fuel turns into a varnish like substance. Check your fuel bowl and make sure there is not any dirt in it. You don't mention the engine manufacturer but, mine has the carb adjustment on the bottem of the fuel bowl. I have always used a fuel stabilizer and keep the tank full (filling it with a screened filter) with a added inline filter. In 20 years of my chipper-vacs life never have I had fuel problem.
Posted on Oct 12, 2009
  • 468 Answers
SOURCE: 5 hp briggs & stratton on a chipper/shreader
if the starter rope fails to retract, then you need to either fix a broken spring, or put a new one in. You'll have to take the engine cover off, and you'll be able to see how to take apart the retractor assembly. Often times, just the end of the spring will break off, and if you have a grinder, you can grind the correct shape in it again, and reinstall it as is.
Posted on Feb 01, 2010
2strokeguy
  • 183 Answers
SOURCE: Briggs & Stratton Van Guard 16 hp D.C. Chipper
Sounds like your carb is flooding. Inside the carb, there is a simple valve that shuts off the fuel flow when the fuel bowl is full. If this valve fails, or if the float sinks, then too much fuel is forced into the cylinder and will wash past the rings and into the crankcase. This causes the engine to run very rich. You need to remove, clean and overhaul the carb, and change the oil and sparkplug and probably the air filter too. Find the model, type, and code numbers on the engine and go to www.partstree.com , www.ordertree.com , or your local repair shop to get the needed carb overhaul kit. Some B&S engines have an option of carbs, so look for a name on the carb itself...probably Nikki or Walbro. The carb kit is not very difficult to install, but make sure to get everything very clean before reassembly.
Good luck.
Posted on Sep 24, 2010
Testimonial: "Bless you...I'll work on it tomorrow and post the results when I'm finished for you to see. Thanks so much. Bob"
Where is the oil sending unit on a 1996 mercury cougar xr7 ? Its cause my oil pressure gauge is bouncing up and down...i dont know why...can anybody please help me thank you so much
The low oil pressure warning lamp will illuminate anytime the ignition switch is turned to the ON position without the engine running. When the engine is running, the light also illuminates if the engine oil pressure drops below a safe oil pressure level. To test the system, perform the following:
If the oil pressure light does not work, perform the following:
  1. Turn the ignition switch to the ON position.
  2. If the lamp does not light, check for a broken or disconnected wire around the engine and oil pressure sending unit switch.
  3. If the wire at the connector checks out OK, pull the connector loose from the switch and, with a jumper wire, ground the connector to the engine.
  4. With the ignition switch turned to the ON position, check the warning lamp. If the lamp lights, make sure the oil pressure switch is properly grounded in the cylinder block, and if so replace the oil pressure switch. If the lamp still fails to light, check for a burned out lamp or disconnected socket in the instrument cluster.
To diagnose an oil pressure light that stays on, perform the following:
  1. Check the engine oil level and top off as necessary. If the engine was 2 or more quarts low on oil, test start the engine after topping off the oil level and recheck the oil pressure light operation. If the light stays on, stop the engine immediately and go to the next step.
  2. Disconnect the wire at the sending unit, then turn the ignition switch to theON position. If the light remains on, check the wire from the sending unit to the gauge for being shorted to ground and repair as necessary. If the light goes out, turn the ignition switch OFF and go to the next step.
  3. Replace the oil pressure sending switch with a known good switch.
  4. Start the engine and check the oil pressure light operation. If the light stays on with the engine running, stop the engine immediately to avoid severe engine damage until the cause of the problem can be determined.
WARNING
If the oil pressure light remains on while the engine is started, stop the engine immediately. Do not operate the engine until the cause of the problem can be determined. Operating an engine with low oil pressure will cause severe internal damage.
Possible causes for an oil pressure light to stay on are:
Pinched or grounded sensor wireDefective oil pressure sending unitRestricted or severely leaking oil filterExcessive internal engine bearing clearance.Insufficient or severely contaminated engine oilBlocked oil pump pickup screen or severely worn oil pump
Mar 31, 2016 | Mercury Cars & Trucks
It starts easy and runs for about 10 minutes and cuts off. Have to wait 30-45 min. to restart with the same cutting off problem. Have always had a problem with restarting even when I shut it down on m
If your oil is too low or even a little bit low or if your machine is sitting on an incline, it will start and run until the oil is dispersed within the motor. Spreading the little amount of oil that is in there all around the inside of the motor would then reduce the amount of oil that is "sensed" by the "low-oil safety shutoff" switch, which would then shut down the engine. Its possible that your "low-oil sensor switch" is bad. You can test it by unplugging it. Just look for a wire that runs from your ignition switch or ignition coil to a sensor mounted on the engine block somewhere. Usually, it just unplugs right at the sensor. Simply unplug it and crank the engine and if it keeps running, then you know you have a bad switch (if you've topped off the oil, of course!).
Jul 07, 2014 | Ridgid Pressure Washer. 3000 psi 2.6 GPM...
HOW DO I CHANGE A BELT ON A DEK CHIPPER
Wrap belt in foil put in 375 oven for 45-60 minutes and it should go on with screw driver as wedge. Use gloves and work fast so as not to let cool off. After install let cool before using.
Apr 24, 2014 | DEK CH1 - 4" 15-HP 420CC Professional Duty...
Whats the purpose of an oil pressure switch can it determine weather oil leaks from your grand prix or not?
The oil pressure switch or sending unit is a unit that receives an electrical signal showing what your cars oil pressure is.And yes it does partially does let you know when there is a problem somewhere in the oil system.For example if your filter gets clogged up your oil pressure will go down and then go up when you accelerate.If there was a leak in the system first you would probably see the leak And if the oil pump or oil pump shaft were to break you would have no oil pressure.So you can see the importance of having an oil pressure switch.I feel there are 2 guages that are important to watch are your oil guage and water temp guage they can tell you allot about how your car is operating.
Feb 09, 2011 | 1997 Pontiac Grand Prix
I need to know where the oli sending unit is and how to replace it?
Fig. 1: Location of the oil pressure switch-3.3L and 3.8L engines
Fig. 2: Location of the oil pressure switch-3.0L engine
Fig.: Oil pressure switch (sending unit) schematic
The low oil pressure warning lamp will illuminate when the ignition switch is turned to the ON position without the engine running. The lamp also illuminates if the engine oil pressure drops below a safe oil pressure level. To test the system, perform the following:
  4. With the ignition switch turned to the ON position, check the warning lamp. If the lamp still fails to light, check for a burned out lamp or disconnected socket in the instrument cluster.
REMOVAL & INSTALLATION
On the 2.4L engine, the oil pressure switch is located on the side of the engine block facing the firewall. On the 3.0L engine, the oil pressure switch is located on the oil filter adapter housing, next to the starter motor. On the 3.3L and 3.8L engines, the oil pressure switch is located next to the oil filter.
  1. Locate the oil pressure sending unit on the engine.
  2. Disconnect the negative battery cable.
  3. Disconnect the pressure switch electrical harness.
  4. Using a pressure switch socket, deep-well socket or wrench, loosen and remove the pressure switch from the engine.
To install:
  1. Install the pressure switch into the engine and tighten securely.
  2. Attach the electrical connector to the switch.
  3. Connect the negative battery cable.
  4. Start the engine, allow it to reach operating temperature and check for leaks.
  5. Check for proper oil pressure switch operation.
Hope this helps (remember to rate this answerr).
Dec 22, 2010 | 1999 Plymouth Voyager
Haven't used our mulching lawn mower - Quantum xm 50 model 125802 for several years. Tried to start it but simply fires up with no trouble but stops straight away.It was w0orking perfectly when last used...
Since the engine was not used up for a very long time , ti will be good that you must first of all change the engine OIL. This is important as a poor oil pressure due to clogging of oil being not used for more than a year is not good for the engine as well as the oil pressure switch might cut off the ignition.
OIl must be changed for usage- like mileage - or time related as the lubrication property reduces.
Secondly you must clean up the fuel section, the tank, fuel filters.
Finally make a check on the ignition, clean the plugs and the trigger contacts/replace if the spark is low.
Since the engine fires up there can be only these factors to be checked. Run the engine for few hours before shutting it down..
Oct 29, 2010 | Garden
My van is Toyota Hiace Dx & when i start my vehical in the Dashboard i can see a yellow color oil can, i want to know wht discribes that sign
The yellow symbol with a line under it means only to warn you if the engine oil level is low when its running. If its RED sign then this is your low engine oil pressure warning light.
Jul 28, 2010 | Toyota Corolla Cars & Trucks
Engine won't stay running
check the fuses which are under the seat
Also it will not run unless the parking brake is set when your not setting on the seat
May 02, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Low oil pressure is shown on read out on dash when key is turned to second stage on ignition.
Is this when the engine is running? If yes, then replace the oil pressure sending unit. If no, it is normal, there won't be any oil pressure if the engine isn't running.
Apr 09, 2010 | 2004 Mercury Mountaineer
Sullair 185 screw compressor
The sullair 185 has a low oil pressure override button that you have to hold in while starting. after the oil pressure builds up(takes about ten seconds) you can release the button and the machine should continue to run.
Feb 19, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
Heavy Machinery Logo
118 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
