Question about Frigidaire Kitchen Ranges
My 7 year old Frigidaire Gallery oven will broil but the oven will not heat up.
  • 2,841 Answers
More than likely the element in the bottom of the oven is defective. Look at it closely for a burnt spot or a spot where it is swelled up. If you see either condition is is defective. If you see nothing then remove the element and with an ohm meter check the continuity of the element. Black probe on one connection and red probe on the other with multimeter set to ohms. If you get no reading the element must be replaced. Most of these elements just pull out. Sometimes there is a screw holding it in place. Make sure to turn the circuit breaker or fuse in your service panel off before working on the oven. Replacement elements can be purchased at any store that sells ovens.
Posted on Apr 26, 2010
Gallery series Frigidaire gas oven not heating up correctly
Hello Hilda, thank you for your post!
There could be a number of
any one of several underlying causes in why the oven is experiencing this
particular issue:
·Convection
heating element
·Thermal cutout
·Thermal oven
sensor
·EOC
(electronic oven control)
·Ignitor,
·Bake or broil
element
·All wired
connections
·Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat.
The parts above will need to be assessed for further evaluation by a technician since it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Aug 29, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Top element wont heat wen oven is on bake
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
Aug 11, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery stove, oven won't heat up (electric)
With the oven OFF, check the resistance of the bake element with a ohmmeter on the lowest scale. Rx1. If your reading is infinate, replace the element as most elements will open circuit when they burn out. They don't short out.
Jul 27, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire range
narrow it down to either the broil coil (upper) or the bake coil (lower). then find the control knob which sets each function and then replace that complete knob assembly.
May 30, 2007 | Frigidaire FEF355 Electric Kitchen Range
Oven heats up very slowly and does not get very hot
Check your power to the oven at the terminals where the power cord connects.Should be 220 volts. Also check the terminals of the bake element for loose connections or a burnt wire.
Dec 28, 2006 | Frigidaire FEB30S5D Electric Single Oven
Kitchen Ranges Logo
56 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
