I have something I've been trying to solve all week, failing with each time. If you can help with this one, as you did a problem I presented yesterday, I'll be sold on your service, which I subscribed to for the 7-day trial period. Are you familiar with the CaringBridge website? I've been able to figure out the basics easily enough. Their website is caringbridge.org by the way. However, when I try to upload a photo, it tells me that my photo is too large. I don't know how to make it smaller. Is this something you might be able to help me out with?
  • kpixley Apr 25, 2010
    I'm amazed that you could even help with this. Wow! Thanks so very much. You're making a believer out of me!
  • 6,993 Answers
yes, you can make the pictures smaller. The picture size is too large for the site, that's why its saying picture too large.
Too reduce the picture, there must be micro-soft office installed on your computer before this can be achieved. I believe you should Microsoft Office on your computer. If so, follow the steps below:
  1. copy out the picture you want to upload on your desktop
  2. Right click on the picture and scroll to "open with"
  3. From open with you will see some options, scroll to Micro-soft office manager
  4. Once the picture manager open, check top of the page and click "Picture" or press Alt + P on your computer's keyboard.
  5. From the picture options, scroll to "Compress Pictures" and click on it
  6. After you click on the "Compress Pictures", you will see an option on the right side of the page.
  7. From the options on the right side of the page, you will see "Compress picture settings", under this option click "Email messages, then look under, you will find 'Estimate Total Size", press OK and your picture will be compressed to the lowest size.
  8. You can then upload the picture, thereafter.
The above is all you need to do in order to reduce the side of the picture. Follow my instructions and its definitely going to work.
I wish you good luck.
Posted on Apr 25, 2010
I've changed my engine mounts 3 times on my 2004 A4 cabreolet and they fail within miles(start to vibrate & then within a week, severe knocking) the 2nd time, also changed the ****** mount, 3r
Engine mounts do not go bad in five miles. Sounds like you're treating a symptom and not the cause of a more serious issue. Are you sure all cylinders are firing correctly? That the severe knocking is not coming from your engine internals? Have you checked the steel around the engine mounting points for cracks or other damage? And just in case, if the mounts you are using are poly, are you lubing them before installation?
Aug 31, 2012 | 2005 Audi A4
I've been able to send sms messages using my iphone 4s overseas from australia to northern ireland, now everytime i try, it keeps telling me message fail, I'm on a plan so its not a credit pro
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Aug 18, 2012 | Apple iPhone 4S
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
From the description you have a hardware problem possibily caused by the ipod plugged into the headphone jack of the laptop. I'am convinced the sound section on the motherboard is damaged, probably the audio output ic. But to trouble shoot the problem will require someone with a strong background in electronics, I would suggest going no further until you have estimate in hand.
Jun 26, 2012 | Computers & Internet
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Failure to start. then will start next day. Mazda said it was fuel pump. They replaced $790.00. did not resolve problem. they kept 2 days and said it was battery. Replaced. @ weeks later same problem.
Well, they probably did put on either a bad fuel pump or should've done the relay.There is also a fuel pump REGULATOR that can cause a lot of trouble. Make them keep at it,since their work should be warranteed when they say they've fixed it. don-ohio
Oct 23, 2011 | Cars & Trucks
My V3 Razor won`t dial somtimes unless I power it off and on.
first u change your mobile software. I think after then your problem is 99% solved if problem present u change your network ic in your mobile mostley the problem is held for network ic when network ic disconnect from your mobile your mobile gave call failed in that case u r not recive any incoming call.u change your network ic your problem is solved.
May 16, 2008 | Motorola Mobility RAZR V3
Mtu keeps saying failed
I assume you mean you can't play games online?
Is your account Gold or Silver? (Go the the Marketplace blade, then down to account information, membership.)
You can only game online with a Gold subscription, which is like $50/year.
May 11, 2008 | Microsoft Xbox 360 Console
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
David Payne
David Payne
