PT-1000 is several years old, but was never used. Powers up fine, all lights work, but the platter will not spin when I push the start/stop button.
  • 104 Answers
Sounds like the belt fell off or is missing.
Posted on Apr 30, 2010
Why did it stop revolving?
The driving element, be it belt or rubber puck, may have failed. It's not an unusual failure in a turntable that is several years old and rarely used.
Jan 08, 2016 | Audio Players & Recorders
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Technics 1200 fault where both the 33 & 45 buttons remain lit, the platter spins at super speed,start stop button doesn't work and the red light is not on
Did you try to de-assemble and clean the contact of this button with contact cleaner, take care to not shoot on rubber parts if you have near the contact, it would blown up !
Apr 28, 2014 | Technics Audio Players & Recorders
My mk5's lights blink when I press the start button?
May i ask which lights you mean, also the pitch? And does after that everything works fine?... then i don't see a problem to be honest. But i'll check my mk5(refurbished really everything only i'm busy with the tone arm wire rewiring, so i can't move it.But now is the time to replace your capacitors for better then standard ones, if you see how old they are and replacing the potentiometres and main wires etc. almost 15 years old. The so calles refurbushing by the often one person stores is a waste of monet, just do it yourself.
Greetings richard and i'll come back on the subject, when the table is ready.
Feb 07, 2014 | Technics SL-1200MK5 Turntable
It won't turn
If the platter doesn't spin then check the belt has not fallen off. It will be seen in a hole under the turntable matt.
Jul 19, 2013 | Pyle PLTTB3U Turntable
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My turntable has stopped spinning when i press start. when i stop it it spins back for a sec then nothing.when i take the plate off the turntable the bit that would spin seams like it can't move free is...
Since it's Direct Drive there's no belt to fall off. There is an electronic brake.
Could your problem have something to do with the Reverse function? Check the L.E.D. Perhaps cycling it will help.
USING THE REVERSE BUTTON:
1. Press the REVERSE (17) button to reverse the rotation of the
PLATTER (2) (the REVERSE LED (17A) will light while in reverse
mode). Press the REVERSE BUTTON a second time to return to
normal play.
http://www.geminidj.com/disc._prod_manuals/TURNTABLES/PT-2100/PT-2100.pdf
Mar 07, 2009 | Gemini PT-2100 Turntable
Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
Apr 11, 2008 | Gemini PT-1000 II Turntable
Technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Oct 19, 2007 | Technics SL-1200MK2 Turntable
 Grubhead
Grubhead
