Question about Canon PIXMA MP160 All-In-One InkJet Printer
Will not print, has an "E" in the window
It says error #1300 paper jam. It is not a paper jam. When I lift the lid the cartridge will not move. I recently replace the black ink cartridge and that is when the problem started.
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
All The Best: Pineworks
Posted on Apr 25, 2010
Paper jam
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 07, 2010 | Office Equipment & Supplies
My Hp 1320 is printing previous jobs on current print outs and is jamming paper
Nov 25, 2010 | HP LaserJet 1320 Printer
Paper jam light on permanently, printer is jammed
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
The problem is cartridge error.I cannot print.what will i do?
Nov 24, 2010 | HP Officejet 4355 All-In-One InkJet...
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
Nov 18, 2010 | Office Equipment & Supplies
Paper Jam {Printer does not detect paper
My printer isnt feeding paper in straight and it keeps on jamming and saying that there isnt any paper.. is there anything i can do to esay fix it???
Oct 25, 2010 | Office Equipment & Supplies
Canon mp830, when turn on error code 6A00. When lift lid, no lights on ink cartridges, ink cartridges do not slide into middle for access. When turn machine on, hear funny noises as heads try to clean...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Dec 25, 2009 | Canon MF3240 imageCLASS Laser...
381 Paper Jam Error
I had to remove every toner cartridge and drum. I found the paper under the second to last drum.
Jan 22, 2008 | OKI C5500n Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
166 people viewed this question
old marine
old marine
