Question about IBM ThinkPad i Series 1400 Notebook
How to get to the cmos battery in a series1400I thinkpad
  • 177 Answers
Remove the keyboard and it's on the lower right hand side of the system board next to the hard drive caddy
Posted on Apr 26, 2010
Reset cmos
Removing the CMOS battery for 15 mins will reset the CMOS.
The CMOS failure most likely is caused by a flay CMOS battery. replace the CMOS battery will fix this problem.
Oct 24, 2012 | IBM ThinkPad T41 Notebook
My ibm thinkpad t41 turns off after sometime when i turn it on...it show cmos checksum bad
Hi:
It is time to change the CMOS Battery Backup, its located inside the unit is the size of an nickle.
Dec 19, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Hello how to reset bios password of ibm thinkpad t23 2647
To unlock the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Take care.
Nov 19, 2010 | IBM ThinkPad T23 2647 Notebook
Were can i find the reset botton of cmos,board of ibm2373 thinkpad
there is a jumper beside the cmos battery if you remove it cmos will be reset
Oct 24, 2009 | IBM ThinkPad T40 2373 Notebook
How do I replace the CMOS battery in a Thinkpad 1400?
Your CMOS battery is located up inside the case. It is fastened to the underside of the palm rest. You may be able to see it if you remove the battery, if I recall correctly. Most generally, you have to split the case to get at it. Do that carefully by removing the screws and prying the case halves apart.
Sep 19, 2009 | IBM Thinkpad I1400 2621 Planar TV...
My R40 Thinkpad loses the system date & time after being shut down for a while. However it does not lose it if only shut down for a few minutes. Any ideas please?
you need to change your cmos cell on motherbord circuit for that open back side cover and then you can see cmos cell on motherbord circuit.Change it pur chase new cmos cell.
Your old cmos cell has not enough waltage so your bios settings are not saved when you turn off the power.
Jul 16, 2009 | IBM ThinkPad R40 2722 Notebook
I get Error 173 and 163 when I start my thinkpad. What can I do?
The Thinkpad POST error code you are getting are :-
163 - CMOS error, clock is not updating
175 - Bad EEPROM CRC
This is caused by either a faulty EEPROM chip or a flat CMOS battery.
Replacing the CMOS battery and go into the CMOS/BIOS configuration and set the Date and Time etc.
If the problem is still there then it is a motherboard problem and depending upon the age of the laptop it may not be worth repairing.
Jul 08, 2009 | IBM ThinkPad X61s PC Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
IBM ThinkPad i Series 1400 Notebook Logo
144 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
