Question about Danby DDR451 Dehumidifier
The compressor of the dehumidifier does not work
I bought a new dehumidifier Danby DDR451, but without any warranty (as is). Since I turn it ON, the refrigeration system (compressor) of the dehumidifier does not work. The fan and humidity sensor working properly (shows humidity level and change it if I am breathing on the sensor. Please help me find out what is wrong
    Guru:
  • 1,524 Answers
Try a hard start kit for the compressor.
Posted on Apr 25, 2010
I have a Danby Silhouette and the fan works but the dehumidifier doesnt.
Bryan, it may imply be a case of the humidity extraction level being set to high. Lower the level to 35% and see what happens. As far as the fan running is concerned. Most dehumidifiers are designed for the fan to run, even if the compressor doesn't turn ON. It's designed to keep the air circulating and if the humidity rises above the setting you have it on, the humidity sensor will pick up this change and turn the compressor ON.
Also, remove the air intake filter to see if it's clogged and needs cleaning. Maintain at least a minimum of 12" of free air space all around the dehumidifier. Poor air circulation will prevent the unit from working properly. As will, to low an ambient air tempeature. Most unit struggle to work at temperature between 40 & 60 degrees F.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 04, 2011 | Danby DDR451 Dehumidifier
I have a new Danby Model #DDR6009REE and have set it up and while the fan operates no water accumulates in the tank. Pressing the switch inside makes no change.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 30, 2011 | Danby DDR451 Dehumidifier
Blowing cool air gets stuck on level wont shut off little water
heatman101
Apr 23, 2011 | Danby DDR451 Dehumidifier
I'am looking for an owner's manual Danby DDR 451
You can get the manual on the link below. Click on where it says it is free PDF then click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/DANBY/DDR451-_E
Good Luck
May 26, 2010 | Danby DDR451 Dehumidifier
My Danby dehumidifier will not dehumidify but the fan works as well as the heat,,,
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 09, 2010 | Danby DDR451 Dehumidifier
E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | Danby DDR451 Dehumidifier
Danby DDR451 water tank
I had this to. Check to see if there is any packing tape just above the tank. The tape on mine was not tapping the tank shut; it had been there for a year (not interfering with anything), but i pulled it all out anyways, and the tank let go!
that's what worked for me... hope this helps
Mar 08, 2008 | Danby DDR451 Dehumidifier
Danby water tank
this part is the indicator to activate the interlock that stop your deshumidifier when water tank is full. It activate a switch on the top right of the placeholder of the tank. when the switch is relaesed it tells you either thank is not there or full and light a red signal. the center of the wheel should be back the pivot. if the pivot is broken, i don't suggest you to forced the switch activated unless you use the direct drain, or you might have water spilled over a full bucket! Martin!
Aug 04, 2006 | Danby DDR451 Dehumidifier
Damby ddr451
Check your tank. Remove it and look to be sure that there isn't any shipping foam or foreign objects in the area which may be keeping the safety switch open. If the area is clear check the switch to make sure that it is not stuck and it moves freely. If that is OK replace the tank and make sure that it is installed completely and correctly. Try it again. If it still does not work I would take it back to the store and have them check it out under the warranty. Good luck.
Jun 29, 2006 | Danby DDR451 Dehumidifier
Danby DDR451 Dehumidifier Logo
469 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
