Epson stylus 4800 pro. Heads are clean. There is plenty of ink. When I test print it does not print anything. No error message. The printer acts like everything is OK. It has not printed since i cleaned the capping stations with simple green.
  • Office Equip... Master
  • 5,346 Answers
My first thought is that the ink gelled in the nozzles. How long were the cartridges out while you cleaned the unit? Try wiping the contacts of the printer cartridge and carrier with a damp cloth (lint-free). If that doesn't work, a syringe without a needle with a short piece of tubing (sized to fit the syringe opening) can sometimes be used to vacuum out the clogs. Just put the end of the tubing against the nozzle opening(s) and pull back on the plunger.
If that doesn't work, try brand new Epson cartridges (not remanufactured).
I hope this helps.
Posted on Apr 25, 2010
  • Cindy Wells Apr 25, 2010
    You said it doesn't print anything when you do a test print. Do you get a blank page out of the printer? Is the printer seen by the computer (and the port set correctly - look at the device manager). Check that the printer is feeding the paper correctly (single sheet can have issues with moisture).
    I hope this helps.
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
How can I replace the ink pad absorbers in Epson Sytlus Photo Printer RX500
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 22, 2010 | Epson Stylus Pro 4800 Color Photo Printer...
Heads will not clean, done everything Epson Stylus Pro4800 Manual says it has cost me a fortune in ink and waste tank. Is there an easy way to clean heads?
Usually the simple way to clean old ink from heads is to get a container of alcohol from the drug store and either using a Q-tip or paper towel soaked - wipe the print surface of the head to remove the old ink, then run the head clean utility once after. If you cannot reach the head surface, move the print head to change ink position, unplug the printer and fold and lay the paper towel soaked in alcohol under the head and manually move the head back and forth by hand to clean it. You may need several sheets of towel and alcohol to do this. Fold the paper thick enough so it will touch the head surface to clean.
Oct 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Can't perform a nozzle check - Sensor error load different paper
Hi tom_kolasa,
Here is the manual for your printer model. Epson Stylus Pro 9800 Printer Guide
http://files.support.epson.com/pdf/pro78_/pro78_gd.pdf
Hope that the manual contains everything you need from nozzle check to sensor errors.
Apr 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
After multiple head cleanings one color still does not print.
Please explain your problem. Do you get a good Nozzle Check? Do not do a bunch of cleanings...you might be just wasting ink.
Nov 11, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson stylus pro 4800 black ink problem
When you put the printhead back into the machine, did you seat the dampers correctly?
Aug 07, 2008 | Epson Stylus Pro 4800 InkJet Printer
Service required error
Try unplugging it for an hour first.
Thanks,
Lee
Jun 18, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
Color test strip is printing each time before a legitimate print is printed
Press the Menu button and scroll to Printer Setup and scroll to Auto Cleaning and turn *Off.
Mar 13, 2008 | Epson Stylus Pro 4800 InkJet Printer
37 people viewed this question
k24674
jasbo
jasbo
