I just bought an Acer Aspire M5620 desktop, running Vista Home Premium, and want to add an older hard drive, DVD writer and a floppy drive (models WD800LB 80 G, Sony DRU-720A and Samsung DFD-321B respectively). All these use wider ribbon connector and different power connectors than I can find inside or on the motherboard, and there seems to be differences with harware fit as well. Am I out of luck with their (in)compatibility?
  • Adam Farkas
    Adam Farkas Mar 26, 2008
    It seems that I have only one IDE connector on the motherboard, but I can use a double connector ribbon for two of the three drives (HD and DVD RW). However, I only have one power connector of the right type for the HD and DVD RW, so I will need a converter. I will also need a PATA to a smaller IDE plug convertor for the floppy drive.
    Do I have it right?
    flak230
  • 19,396 Answers
All 2.5 IDE hDD have same connector
Posted on Mar 23, 2008
  • Ginko
    Ginko Mar 23, 2008
    Sorry, the answer was for a different solution. In your case your computer uses SATA hard drives (on ports) that work on a different way from older IDE (PATA) hard disk. That is the reason why connector are different
  • Ginko
    Ginko Mar 23, 2008
    However in your motherboard you should have two IDE connectors to install PATA drives, if you connect an IDE ribbon cable to the PATA connector on motherboard it should work.
    Another solution may be buying an hard disk usb external caddy (the enclosure for external usb hard disk) and mounting the old hard disk in the external caddy, so that you can use it as an external disk. This will be much easier.
    Note PATA technology use parallel data, SATA serial. SATA data transfer rate is much faster then PATA. If you can do not repalce your SATA hard drives for PATA.
    regards
SOURCE:
Acer aspire z3101 u4062 can i use the monitor for another pc without running the acer aspire?
Yes just use the same connections
Processor AMD Athlon II X2 240e / 2.8 GHz
Memory 4.0 GB / 8.0 GB (max)
Hard Drive 1.0 TB
Operating System Microsoft Windows 7 Home Premium 64-bit Edition
Optical Drive DVD RW (R DL) / DVD-RAM
Graphics Processor NVIDIA GeForce 9200
Graphics Controller Integrated
Monitor Type LCD display
Oct 07, 2013 | Computers & Internet
I have an Vista running Acer Aspire t180 desktop that i bought in 2008. i would like to restore it to its factory settings but i have misplaced the restore disks and Alt-F10 does not work. My eRecovery was...
Your options are either go to Acer for a replacement Vista recovery DVD or
Install a borrowed Vista DVD, must be same Vista Basic, Home Premium,
then use your registered CD key, normally located on the side or rear of your tower.
It will also tell which Vista type you have. You then must go to the Acer support site
and install then drivers for the componenets in you computer.
You will not have any other software installed that may have come with your
original setup from Acer. This option requires more work on your part, but
no cost to you. Acer will charge for a Recovery DVD, plus S&H.
Aug 24, 2011 | Acer Aspire T180 PC Desktop
Just want to now what is the biggest duo 2 cpu can you put in the acer aspire l310 desktop
This is the standard equipment for your model.
Problem is, your system is already maxed out for heat.
If you add a faster CPU, you will most likely suffer from overheating, but yes you can add up to a 3 gig+ duo with no problem fitting it in the socket. Expect your power supply fan to run constantly though.
Processor: 1.86GHz Core 2 Duo E6300
Memory: 1GB DDR2
Storage: 320GB hard drive
Optical Drives: Double-layer DVD±RW
Monitor: None
Graphics: Integrated Intel GMA 3000
Operating System: Windows Vista Home Premium
Aug 30, 2010 | Acer Aspire L310 (ASL310UD631A) PC...
I have formatted the sata hard drive & can't re-install windows Vist home premium the CD rom will not run? I do not have any driver or boot drivers, can you advise as to what drivers I requir & to...
Phil, you have no choice but to buy a new CD-ROM.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5541391&CatId=89
You have the Vista CD and it must be installed. As far as drivers for the Aspire M3641 MB. They can be down loaded from the link provided. http://gd.panam.acer.com/home/
From Select Product Family click on Desktop.
Click Aspire from product line.
Than click Aspire M3641 from model.
All needed drivers will be listed for you to download.
Cheers'
Mike
Jan 27, 2010 | Acer Aspire M3641 Dual Core E2200 PC...
To buy pc
I would recommend a Dell Inspiron 531. They can be slightly hard to find, but they are cheap and pretty fast. Here are the specs for it:
300W LITE-ON PSU
2.2 GHz AMD Sempron LE-1250 CPU (waaaay faster than it sounds)
nVIDIA Integrated Graphics
Realtek HD Capable Integrated Sound
Dell 0RY206 Motherboard
PBDS DVD-ROM/CD-RW Drive
160 GB WD HDD
2 GB DDR2 RAM
May 18, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
My Acer Aspire 5610z laptop drivers are corrupt
Hi Garvoyee, try this program which will help repair your windows registry& blue screens;
http://www.zaperrors.com/?t202id=911719&t202kw=code%2039&gclid=CP2Y1_3cw5gCFQpuGgodSBwR0g
Below is Acer link: (Drivers for both XP & Vista) There is no 5610z, only Aspire 5610.
http://support.acer-euro.com/drivers/notebook/as_5610.html
Feb 03, 2009 | Acer Computers & Internet
TEAC floppy drive won't work with Vista Home Premium
Have you tried WWW.Driverguide.com - Generally I have found all the drivers I need there. Else try the manufacturer's web site at www.teac.com
Aug 15, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Open Questions:
AOL MAil TelePHoNe NuMbER {1^/855~/536~/5666-} SERVICE This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 22, 2019 | AOL Computers & Internet
AOL MAil Toll Free %%%{1=855=536=5666}#[email protected]@# NuMbER SOLVE This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
amazon prime refund number 1-************ amazon prime refund Tech Support IKMBUGA [email protected]@refund is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the [email protected]@refund email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. [email protected]@refund support number When you are using the [email protected]@refund for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the [email protected]@refund support number and ask for the help. Once you dial the [email protected]@refund customer support number, you come in contact with a team of experts at the [email protected]@refund customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the [email protected]@refund support phone number will help you with that simply and quickly. This is [email protected]@refund's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a [email protected]@refund agent. Features of [email protected]@refund support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the [email protected]@refund customer support phone number. Here are some of the features of customer service: The [email protected]@refund customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the [email protected]@refund customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this [email protected]@refund provides you the facility of [email protected]@refund support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the [email protected]@refund. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the [email protected]@refund Customer support number team.
Oct 22, 2019 | HIS Computers & Internet
Computers & Internet Logo
42 people viewed this question
Ekse
Marvin
Marvin
