Question about Nintendo Wii Console
Asking me to press [a] to start after pressing still asks
  • 3 more comments
  • charles hower Apr 25, 2010
    trying to start any game
    i dont know if remote strip is working
    having problems trying to play wii keeps asking me to press [a] to start changed 2 differant games
    after i charge batterys do i 2 do anything 2 calibrate
    no guitar hero
  • Nintendo Master
  • 12,061 Answers
Hi, I would wonder if you haven't gotten a bad controller? If the Software accepts, your "Input" from the (a) Button, and yet still "Asks" for it to be pressed, again, is very unusual, IF after pressing, it doesn't work at all, then most definitely you have a faulty Controller, or controller port. You need to isolate the problem. IF The Nintendo, does NOT respond to the Button, at all. then you will have to try another controller to test it. Now IF it works, after you press the button, but STILL asks you to press it, then you STILL need to swap out the controllers to prove, IF using another controller, a Know Good" one, then your Nintendo, has developed a curious fault, internally, and will have to go back to Nintendo for repair. Also you could try disconnecting from the mains, disconnect and reconnect all controllers, also try "other" games and see if the problem "Follows" form program top program.
http://www.blogcatalog.com/blog/troubleshooting-wii-nintendo-wii-repair- manual
www.nintendo.com/consumer/systems/wii/en.../wiiremote.jsp
www.nintendo.com/consumer/systems/wii/en_na/system.jsp
www.ehow.com › ... › Video Game Accessories
www.ehow.com › ... › Nintendo Wii - 5 hours ago
http://www.somelifeblog.com/2008/01/wii-repair-fix-guide-error-nintendo.html
Ok, links above, directly above, a how to do everything.. above that, is a how to test controller, above that is how to set up, above that is more about the controller, Please check out ALL links, that way you can get all the info.
Posted on Apr 26, 2010
Are you using the Nintendo Wii Fit Balance Board when you get this message?
Posted on Apr 25, 2010
  • 643 Answers
Thank you for asking your question on Fixya..
Is it during a game that that you are getting this message?
if so, what game?
  • 1 more comment
  • Tre Elkins Apr 25, 2010
    Have you checked the batteries in the remote?
    It may not be syncing up to the wii, this could be due to low batteries or maybe just the controller needing to be calibrated..
    so check the batteries,
    replacing them is probably a good idea, especially if you cant remember the last time it was replaced..
  • Tre Elkins Apr 26, 2010
    try resyncing your wii remote now that you have replaced the batteries..
    you need to press both the red button on the wii, and the one on the controller at the same time..
    here is a more detailed description..
    http://www.ehow.com/how_2144692_sync-wii...
  • Tre Elkins Apr 27, 2010
    not sure if you seen the last message i sent.. wondering if it helped you, or your still having issues.
4 Suggested Answers
SOURCE: Balance board keeps asking me to step off? Even
When you get that message, pick the board up, press A and hopefully it will work for you. I had the very same problem, saw this solution online and it did the trick.
Posted on Dec 15, 2009
  • 20 Answers
SOURCE: Stuck on Language settup screen
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
jeonatumi10
Posted on Jan 06, 2010
ib_yang
  • 1098 Answers
SOURCE: step off the board and
Hi.
This is a common issue for the Wii Balance Board. Here is how you do it:
  1. Take the batteries out.
  2. Take out the screws from each foot in every corner of the board using a Philips screwdriver. Remove the back cover.
  3. The sensors are located on each corner, it is a metal plate. Loosen the screws using TORX screwdriver.
  4. Re seat the small metal plates by putting it back. Don't screw too tight.
  5. Put the cover back and foot on. Put the batteries back in.
I have also written a tip about this with video, you can visit it here.
Hope this helps!
Posted on Jan 09, 2011
How do you reboot aspireone
I will assume that by reboot you understand reinstall the operation system and I will give you the options for it ..
First and the most simple way is to use the recovery partition some laptops came with from factory , and reinstall eh system completely .to do so you need to have one ..and to engage it press F11 on start or press f12 to get the boot menu and choose the partition for recovery from the menu and press enter .This will start it and you probably have some options for repair or reinstall from scratch ..If you do not know the exact key ..take a close look when it starts cause it is indicated on screen ..
Another way it is to use a recovery disk ..and the procedure is to start the computer with the disk inside and if it asks you to press any key to boot from the disk do it and will start the recovery ..If it does not asks it means the boot order have to be changed from bios .To do so ..press F2 on start and go to bios ..and in there select advanced settings ..and under the boot sector ..select the CD /DVD to be the first boot device ..After selecting it press F10 to save the settings and restart .It will work .
3rd posibility in case there is no recovery disk or partition available is to use a boot-able disk with the operation system on it , and same way ...Insert the disk ..be sure you select the boot device in bios ..and press any key when it asks to start installing the OS ..Or ..if you do not want to mess with bios settings ..just insert the disk ..and restart ..and press f12 right the way ..and in the boot menu ..select single action boot from disk drive ..and enter to engage ..it will ask to press key to confirm and start loading files..
When you get to the agreement you confirm it ..and after that select the C drive for to install into it ..and go on ..(I suggest to format the drive in quick mode (ntfs )
Dec 23, 2011 | Acer TravelMate 2413LCi Notebook
How do I install my Win XP whn I have changed my harddisk ?
plz follow the steps...
1. Insert windows xp bootable cd into the drive
2. Power on the machine
3. When the logo displays, press F12 to show the boot menu
4. Select the CD/DVD
5. System will start the job
6. After showing Setup is starting windows, it'll shows the install option
7. Press ENTER
8. It'll show the drive but the drive is not partitioned
9. You can easily understand by reading the instructions
10. While creating it'll ask for drive space
11. Put 50000
12. Press ENTER
13. It'll ask for type of file system that you have needed, select the 1st one (Quick using NTFS)
14. It'll ask 4 format the specific drive. for that you have to press 'F'
15. It'll format and copy the needed files
16. System will restart. After restarting it'll start the job. plz wait.....!!! (system restart many times to complete its job)
17. While working it'll ask for the product key, time, etc.
18. Sit infront relax and give the needed information that you can understand easily
thanks & regards
Anas K A
May 28, 2011 | Fujitsu Lifebook T1010 Tablet PC
How does one 'colour test' please.
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink button on the control panel and select CLEANING press OK.
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps Please rate if it worked Thanks!
Apr 03, 2011 | Brother MFC 490cw Color Inkjet...
Spell check is on. wants to stop spell check
hi
  • If you start writing a message in phone check whether the Dictionary is ON or not..
  • If its ON then it asks the spell check
  • so,go to write message then ->press #button no.of times the abc format comes then start typing it won't asks the spell check..
  • otherwise press the left top button a -> it shows the list of options press -> dictionary OFF
  • then it won't ask spell check...
Jan 06, 2011 | Nokia 3120 Cellular Phone
Pls help me...my antivirus deleted files on my windows, and when i restart my computer it won't function properly anymore,,is it possible to reinstall windows w/o losing my programs?
Yes it is. You can reinstall Windows without losing any programs.
Insert Windows XP CD in CD Drive-->Restart Compute--> While compoter will boot up, it will ask to "Press any key to boot from CD ROM"-->Press Enter-->Then Windows Installation will start-->Installation processure will get stop at one momenet when you it will ask you to select serveral option i.e. Press "R" to Repair from Recovery console, Press "c" to continue-->Press "Q" to Quite-->Press "C" here to coninue--> Then after it will goes to next screeen and again ask you to select sereral option--> Here press "R" to repair windows and it will start repairing windows-->It will restart computer several time, here please do not press any key of keyboard otherwise installation process will be restarted again.
Mar 01, 2010 | Microsoft Windows XP Professional
HOW CAN I GET INTO THE ASK MODE ON MY CALCULATOR
  1. Press [2nd][WINDOW] to access the Table setup screen.
  2. Use down arrow to move focus to the line Indpnt: Auto Ask
  3. Use right arrow to highlight Ask and press [ENTER]
  4. Focus moves to line Depend: Auto Ask
  5. Use right arrow to higlight Ask and press [ENTER]
  6. Press [2nd][MODE] to (QUIT) the table configuration screen.
  7. You can now create your table.
Feb 07, 2010 | Texas Instruments TI-84 Plus Calculator
Replaced drum cartriddge on model AL-1661CS and still has error reading to replace cartridge
After replacing drum catridge you should reset the drum counter in the following way
1.Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying
2.Now press the following sequence of buttons: [CLR], [AURO], [CLR], [AUTO] all thes one by one
3.Your unit should turn off the numbers in the panel
4.Now press 24 as if asking for 24 copies and press [START].
4.Now press 07 as if asking for 7 copies and press [START].
This should reset your drum and it should stop flashing
RNJ VINOD KUMAR
Sep 15, 2009 | Sharp Office Equipment & Supplies
Dell M70 laptop won't boot up
If you have a Windows installation CD, you can use the Recovery mode to attempt to fix the problem.
Turn on computer, insert CD into drive.
Windows installation process will start
After a few minutes, a screen will come up telling you to hit ENTER to install Windows, or to press R to enter the Recovery Console
Press "R"
You will be asked which operating system
Most times there is only one option, select 1
At command prompt, type "fixboot" and press ENTER, if it asks if you're sure, type "Y" press ENTER again
Then, at command prompt, type "fixmbr" and press ENTER, again, type "Y" and press ENTER if it asks.
Type "exit" and press ENTER to exit recovery console and reboot.
Give that a try and see if it will boot for you.
Mar 08, 2009 | Dell Precision Mobile M70 Notebook
Gateway 9500 windows wont start
these are essential windows files you will need to reinstall windows in repair mode
set bios to boot from cd you will during boot up be asked to press any key to boot from cd press any key when widows loads all its drivers etc windows will ask what you want to do press r for repair and follow instructions
during setup windows will reboot a few times when it does do NOT press any key
Jul 27, 2008 | Gateway SOLO 9500 (7002886) Keyboard
FAX to Email 1820E
press the fax/email button.. then press function -7-2-start- 1 for one touch or 2 for abbr. and when it asked you to enter a phone number press the fax email button and it will ask you for an email address instead
Jul 08, 2008 | Panasonic Workio DP-1820P Laser Printer
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
