Question about Bosch SHU9915UC Dishwasher
The upper spray arm is not working. Any suggestions on what I might do?
    Scholar:
  • 126 Answers
THE SPRAY ARM IS CLOGGED.
YOUR FILTER IN THE BOTTOM IS CLOGGED.
THE TUBE THAT FEEDS IS HAS A BREAK GOING UP THE BACK WALL.
LACK OF WATER. ADD WATER SEE IF THAT WORKS. THEN YOU WILL NEED A VALVE.
THE SPRAY ARM TUBE IS NOT GOING INTO THE BACK OF THE FEED TUBE.
Posted on Apr 25, 2010
Why is the top spray arm not turning
All of the water coming to the upper spray arm comes through the feed tube. If the feed tube is blocked or the probe flapper is hung open, water will not flow properly to the upper spray arm. Be sure that when you push in the upper rack the manifold probe is in position in the feed tube. Try adding more water in the tub to see if the upper spray arm starts rotating. Other possibilities; low water charge, cracked spray arm & poor wash pump performance.
Jul 28, 2016 | Dishwashers
Why doesn't upper spray arm function properly?
A couple of scenarios could cause this problem but the simplest might be the way the dishwasher is loaded. The upper spray arm rotates when water is pumped through the vertical supply tube and into the arm. Make sure that you are not loading the lower rack with items that interfere with the rotation of the upper arm rotor. It might also be a good idea to verify that the feed tube that goes to the spray arm is securely connected to the vertical supply tube.
Dec 02, 2015 | Kenmore Dishwashers
Upper spray arm
Hello Alan - Will the spray arm rotate freely or is it damaged? If so, you might have to remove and replace the spray arm assemblies. The top spray arm typically starts to function when the unit is in rinse or wash cycle. If for some reason the top rack is not getting clean, there is a possibility that it is not working properly. The top spray arm is either blocked by pots/pans or not enough water pressure is being pump meaning that the flow of water is not making it to the upper spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately, then the problem may lie with a faulty pump or impeller. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Jun 24, 2013 | Frigidaire 24 in. FDB126RB Built-in...
Top spray arm does not spin
The upper spray arm is powered by water from a tube that runs up the back of your machine on the inside. If the connection is not aligned, then the water can't get to the spray arm. My children use to knock mine out of kilter when they loaded the lower section. It's easy to see if the supports are not attached to the upper rack and a simple snap will get them back in place.
It may also be that the spray arm jets are clogged.Depending on the model, the upper spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then remove the arm. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure..
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 21, 2011 | KitchenAid Dishwashers
Top rack does not wash dishes.
Possible causes of spray arm inefficiency:
Loading large or tall items in the lower basket which stops the arm revolving.
Upper spray arm split along seam.
Upper spray arm blocked.
Under dosing of powder causing foam and reducing upper spray arm water pressure.
Blocked strainers reducing water to circulating pump, therefore reducing upper spray arm water pressure.
inefficient wash motor impellor (faulty)
Dec 21, 2009 | Kenmore Dishwashers
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Sep 22, 2009 | Dishwashers
Upper Spray Arm in the dishwasher has fallen off
If you cannot just twist it so it screws back on a part was broken.
So I suggest you contact the manufacturer about this. Im sure that will be much more helpful!
Feb 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Glasses on top shelf
possible grit you are feeling is from the water softener breaking down. the softener contains a brown resin. this ofted happens if you have connected supply to hot water. best connect to cold
Apr 25, 2007 | Hotpoint 24 in. HDA2020Z Built-in...
Bosch SHU9915UC Dishwasher Logo
190 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
